ucd 25 watts to 1200 watts using 2 mosfets
Old 4th August 2012, 08:54 PM   #2161
Whortless is offline Whortless  Turkey
Whortless's Avatar
Originally Posted by stewin View Post
hi whortless
which is the best transistor to use as buffer in totem pole . to drive 4 pairs irfb 4227 or irfp250 or irfp264 or (irf640 6pairs)?? will the 2SB772/2SD882 work or there is a better pair.
I never used totem pole drivers after a specially designed IC. Never need to use one except the previous discrete UCD amps. However, They should be high HFE and low Vce sat. ones. They should be for switching purpose. The Vce of the complementary pairs are not so important if they can work within the Vboost or Vdrive voltage range. Hence, the pairs i suggested can do the job. In my previous designs i used philips 5240T as fast turn off. And used Maxim 7.2A SOT23 mosfet driver to drive heavy mosfets like IRFP250.
In my view BD911/912 can be used as an output of a 50-70W class AB amp and using them as totem pole drivers not a logical approach to Class-D design. There are several BJTs around from Sanken, ZETEX or Philips for this purpose. Try to find out best for your purpose. Try to get a set of transistors as samples.
Good luck,
BW
Old 5th August 2012, 03:36 AM   #2162
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
Originally Posted by exflaco View Post
Dont forget the lower conextion the gnd from v rails to the gnd input (single wire)
have u built it? there's even some difference between the schematic and the pcb. but the most problematic is the cd4049 pinout which is totally different from the datasheet and schematic compared to the pcb. the pcb shouldn't work, but i wonder if anyone did manage to.
Old 5th August 2012, 06:21 PM   #2163
sweetperfume is offline sweetperfume  India
i managed to make this thing work but dint get any much success......on low volume it works as clean as a headphone does but when increase volume there is a distortion in the speakers...like someone is tearing papers......help me out with this issue??????
Old 5th August 2012, 06:52 PM   #2164
stewin is offline stewin  Kenya
thanks Whortless i,ll try bc327 and bc337 do they meet the requirements?
Old 5th August 2012, 06:54 PM   #2165
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I use BD244/BD243 with 4 irfb4227.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 5th August 2012, 06:57 PM   #2166
Old 5th August 2012, 07:19 PM   #2167
they are same as tip41 and tip42?
Old 5th August 2012, 07:45 PM   #2168
hi guys please help this amp works fine with +/-45vlts 8amps with irf540/540n/640n two pairs . they dont even warm when playing loud without a heat sink.
but when using irfp250 /irfb4227 two pairs at +/-60vlts 1amp they get hot in the few seconds of playing. pls help me out guys
artwork and pcb diysmps
thanks in advance
Old 5th August 2012, 10:28 PM   #2169
Whortless's Avatar
It depends on what speed and current (Cg) you will work. BC639/640 seems better.
Old 6th August 2012, 04:24 AM   #2170
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
can you post some photo so we can see what, where is the problem
top and bottom
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
