ucd 25 watts to 1200 watts using 2 mosfets
Old 1st August 2012, 04:15 PM   #2151
alfel is offline alfel
BD139 BD140 low ampere 1,5A BD911 NPN 15A BD912 PNP 15A
Old 2nd August 2012, 10:23 PM   #2152
stewin is offline stewin  Kenya
are those with hi amperes needed ? iraud 9 uses 600ma to drive irfb4227 4 pairs.
Old 2nd August 2012, 10:25 PM   #2153
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The irs2092 will output 1.5 amps and I couldnt get it to drive 4 irfb4227 without the chip resetting. In fact it struggled with one pair.
To get it to work I had to add npn/pnp gate buffer BD243/BD244.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 3rd August 2012, 01:38 AM   #2154
so tip 41 and tip 42 can do well i believe they have high amps.
Old 3rd August 2012, 08:20 PM   #2155
guys is it o.k to use tip41 and tip42 in the totem pole gate buffer ??
Old 3rd August 2012, 10:35 PM   #2156
Whortless is offline Whortless  Turkey
Whortless's Avatar
Try, 2SB772/2SD882 instead of BD139/140.
Old 4th August 2012, 01:14 AM   #2157
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
pls look also the bandwidth of those bjt not only the current capability ..pls correct me if im wrong
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 4th August 2012, 08:19 AM   #2158
hi whortless
which is the best transistor to use as buffer in totem pole . to drive 4 pairs irfb 4227 or irfp250 or irfp264 or (irf640 6pairs)?? will the 2SB772/2SD882 work or there is a better pair.
Old 4th August 2012, 07:13 PM   #2159
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
Originally Posted by thienchay View Post
I'm used IRFP460 , schottky Diode is better , and R gate i using 22 ohm
Sorry All , diode boostrap is FR207 or Diode has Vrrm >= Vcc .
And this is my last check .
hi thienchay. have you built the irs900 pcb? seems that the pcb is different from the schematic at the cd4049 chip.
the pinout for the cd4049 chip is messed up at your pcb and at the original pcb from detex. anyone have successfully built the irs900d?
Old 4th August 2012, 07:31 PM   #2160
exflaco is offline exflaco  Armenia
Dont forget the lower conextion the gnd from v rails to the gnd input (single wire)
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
