Go Back   Home > Forums > Amplifiers > Class D
Old 26th July 2012, 03:47 PM   #2141
apexaudio's Avatar
Originally Posted by exflaco View Post
Sir Apex Could share pcb for D500 ,tanks a lots or only a proyect,not tested?
I can share pcb, but not tested.
http://apexaudio.rs/
Old 26th July 2012, 09:02 PM   #2142
exflaco is offline exflaco  Armenia
Hey sir Aper i work very hard on your Friendly DIY apex D500 ,never work ,yours clas AB and H very respeted in DIY forum ,y dont undestand because ,share bad schem and boards not tested , realy a joke ,Diyaudio the best.......
Old 26th July 2012, 09:07 PM   #2143
Irvineyay ,the original IRS900 use IRFP250 and 100 ohm gate resistor?
Old 27th July 2012, 12:12 AM   #2144
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
yes gate resistor vary when other fets used
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 27th July 2012, 05:03 AM   #2145
abetir is offline abetir  Philippines
Originally Posted by t68kv View Post
IRS-900
T68kv, sis favor can you post the diameter size of the toroid inductor and the wire gauge plus the no.of turns...?
I'll see if I can find similar size's on 2nd hand boards being sold in Raon area, I've been seeing a lot of boards with toroids in it, I can't DIY at the moment I just burned my pcb drill I might as well go parts hunting for the meantime.
Thanks!
Old 27th July 2012, 10:51 AM   #2146
t68kv is offline t68kv  Philippines
Abet,
Out Dia - 1.2"
In Dia - 0.7"
Height - 0.4"
Approx 20-22 turns of 16AWG
Remember, not all core have the same permeability value. I suggest that you also try using ferrite EE with gap 1-2mm gap.
Old 30th July 2012, 02:44 AM   #2147
^ OK! thanks,
My etched pcb for IRS900D (done manually), thanks Thien!
(Sorry, been using cellphone cam )
Old 1st August 2012, 04:32 AM   #2148
Default Hello
Hi Exflaco
greetings please check pcb with schematic for mistakes
sameerx1
Old 1st August 2012, 01:00 PM   #2149
The tl084 power rail must be uncouple with 2 pairs 0.1uf and 25uf 50v respect to gnd (pin 4 y 11t) and the uper side totem pole 1n4148 is inverting, more late y see you more mistakes if find it, tanks exelent design sorry poor english
Old 1st August 2012, 02:33 PM   #2150
andrewlebon's Avatar
Hi Sameerx1
greetings scrap this design gate tracks are to long make it like triell 1500 watts
warm regards
andrew lebon
[image][/image]"It's Better to try and fail than to never know and always wonder"
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
