ucd 25 watts to 1200 watts using 2 mosfets
Old 24th July 2012, 06:09 PM   #2131
exflaco is offline exflaco  Armenia
Sir Apex Could share pcb for D500 ,tanks a lots or only a proyect,not tested?
Old 25th July 2012, 05:27 AM   #2132
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
hi guys i have a little problem with che900 amp ,i changed the tl071 with a opa134 and i have some DC offset when i power up and power down the amp makes a loud boom on spekers ,is there a way to reduce the dc offset ?
Old 25th July 2012, 05:31 AM   #2133
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
how much dc offset you have ,,pls check voltage on zener 5.6v -/+ if what dc you have then check for short on TL0 side i never get that problem on irs900 offset 1.2mv
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 25th July 2012, 05:57 AM   #2134
ill mesure today the offset but i have OPA134 instead of TL071
Old 25th July 2012, 06:38 AM   #2135
irvynejay's Avatar
pls look datasheet of those ic and compare thanx
Old 25th July 2012, 07:29 PM   #2136
alfel is offline alfel
Default irs2092 ok frend 6.8v:)
Old 25th July 2012, 08:30 PM   #2137
Default Poor man class D laboratory
And much time experimment
Old 25th July 2012, 09:35 PM   #2138
alexclaire is offline alexclaire  France
Default Irs2000d OCP resistor value
Hi everyone,
For those looking for OCP res value : for example 100 ohm
Some Maths:
Vref (LM311 pin 2) is 12*100/(6800+100) = 174mV
Iout(trip) = Vref/0.01=17,4 A
You can change ocp res value to suit your needs.
Old 26th July 2012, 02:20 AM   #2139
JLesterP is offline JLesterP  Philippines
Do you have OCP for IRS900? How to implement it?
Old 26th July 2012, 09:02 AM   #2140
t68kv is offline t68kv  Philippines
IRS-900
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
