ucd 25 watts to 1200 watts using 2 mosfets - Page 212 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th July 2012, 10:00 PM   #2111
yeah andrew,
try using higher value for the output inductor, my last test with ejtagle's circuit, i used about 180uH inductor, it gives more punchy sound...... more kick shall i say and one more thing some noise were gone.
Old 18th July 2012, 10:31 PM   #2112
andrew,
this is the one i used for ejtagle circuit, almost 180uH, 50turns #18 wire 27mm OD for the core, but it was factory wound core. a friend charge me a couple of bucks for the windings, he had a small company dealing with transformer.
thanks to mr. tagle for his circuit, i learn a lot of basics from this...
Old 19th July 2012, 05:03 AM   #2113
de Ocampo's Avatar
Originally Posted by thienchay View Post
Hi
This is my PCB file .
thienchay! you are very helpful... One more thing I see you are using 1N5819 (schottky barrier rectifiers) and 27ohms gate resistors (original was 10ohm). What type of MosFET are you using and at what rail voltage?...
Cheers!
Old 19th July 2012, 12:17 PM   #2114
thienchay's Avatar
Cheers!
I'm used IRFP460 , schottky Diode is better , and R gate i using 22 ohm
Sorry All , diode boostrap is FR207 or Diode has Vrrm >= Vcc .
And this is my last check .
Old 19th July 2012, 03:07 PM   #2115
exflaco is offline exflaco  Armenia
Gerry could share pcb bridge you show picture simil triell ?
Old 20th July 2012, 08:35 AM   #2116
Hello maybe who heve
detex-audio Class D Amplifier IRS-3000D scheme?
Old 22nd July 2012, 11:51 PM   #2117
Algel the same irs900 plus lm311 555 protction look schematics irs900 anterios postdetex2.PNG
Old 23rd July 2012, 05:04 AM   #2118
Send a message via Yahoo to ionutzxpo
hi,what is the values of R-OSC/RFB/OCP ?
Old 23rd July 2012, 05:07 AM   #2119
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
1k/100k/?????
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 23rd July 2012, 12:52 PM   #2120
Irvi Tien Ionutx Alfel
RSS/2W 70v 4.7k/2w 90v 6.8k/2w
RFB R 68k-220k (100k)
R OSC 1k
ic gate drive ir2110
ic inverter cd4049
ic compara input TL071CP
ic protection ic 8 LM311 2 ic NE555N ic
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
