ucd 25 watts to 1200 watts using 2 mosfets
Old 14th July 2012, 02:15 PM   #2091
exflaco is offline exflaco  Armenia
WOW::: the planet bigger......a 600 600 ohm aislattion
amplificador classe D 4700wrms 1ohms o mais potente do mundo C/ 142x142mm e peso 450g - YouTube
Old 15th July 2012, 05:38 AM   #2092
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Originally Posted by thienchay View Post
Hello all Diyer
This my new class D , and i 'll checking it soon .
Thienchay, nice spacing you got there, it looks like you are using different parts is it a modified version? any plans on sharing the bottom artwork for toner transfer?
Hi all!,
I wonder if anyone of you had a clearer resolution of the pdf file for DIY share, using Detex IRS900, I have the Detex artwork but I don't think it is going to be successful on laser toner transfer, the image is so poor
Old 15th July 2012, 07:56 AM   #2093
stewin is offline stewin  Kenya
Hi all!,
hi Thienchay , please remember the schematic also
Old 15th July 2012, 10:26 AM   #2094
t68kv is offline t68kv  Philippines
@abet
Try using cheshtap's remake of irs-900d.
Old 16th July 2012, 04:04 PM   #2095
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hello
geetings what should be the ideal permeability of core for dclass core since i am not so sure is 125 permeabilty the best core material in SENDUST KOOL MU material
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 16th July 2012, 04:18 PM   #2096
Sendust Toroidal Cores for Chokes and Inductors : CWS ByteMark, largest supplier of toroids, ferrite cores, iron powder cores, MPP cores and RF cores
Old 16th July 2012, 08:32 PM   #2097
STAGE4 is offline STAGE4  Sri Lanka
STAGE4's Avatar
Run Test 2 Reggae TC vs BTJ totem load 2kw per amp 2 ohms - YouTube
hm.....red red wine
Old 17th July 2012, 02:06 AM   #2098
gerry_morales is offline gerry_morales  Philippines
hi andrew check yorkville service manuals for class d powered speaker, they are using cool mu cores. magnetics 77191-a7 if i remember it right
Old 17th July 2012, 02:08 AM   #2099
hi Gerry
greetings thanks for the information how are your d class amps playing
warm regards
andrew lebon
Old 17th July 2012, 01:03 PM   #2100
Gerry yorkville use d class only in subwoofers at low frecuencie clocks ,many cores work fine ,full range hummmmmm........
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
