ucd 25 watts to 1200 watts using 2 mosfets
Old 10th July 2012, 08:35 PM   #2081
exflaco is offline exflaco  Armenia
Stewin the protection work fine short circuit, and low imp ,tested
Old 10th July 2012, 08:40 PM   #2082
Aucosticraft the 3200 is for sub low d'ont work fine at complete range ,a good PA class D lows , class H mids , And class ab higs
Old 12th July 2012, 02:39 PM   #2083
Sameer you pcb a litle mistaque the-v rail is floating must be conect the zener positive to grnd ,coul share speaker delay and dc protect schematics'? tanks
Old 12th July 2012, 03:01 PM   #2084
CPX is offline CPX  Romania
Originally Posted by Aucosticraft View Post
Has anyone seen the performance of this amp with 20Khz input signals ?
its giving me problem when I Use 20Khz as input or mix 20Khz with 1Khz signal. the circuit stops oscillating.
You have bad layout..post it so i can give you some advice.
Old 12th July 2012, 03:10 PM   #2085
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
"Un site d'audiophile" enceinte en béton - amplificateur mosfet ...
hi Exflaco
greetings this is the site for dc protect schematic posted by sameerx1 use BC547 BC557 for bc560 550
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 12th July 2012, 04:49 PM   #2086
Thanks a lot andrew lebon ,diyaudio the best diyers choice
Old 13th July 2012, 12:24 AM   #2087
stewin is offline stewin  Kenya
thanks exflaco. pls post schema
Old 13th July 2012, 04:08 AM   #2088
Aucosticraft is offline Aucosticraft  India
Thanks CPX, but the problem was when I simulated.but When today I re simulated it, it worked perfectly fine. ( I do not have oscilloscope.)also the physical amp sounds good.I am loving it.
There is always a first time....
Old 13th July 2012, 04:53 AM   #2089
About selection of Strands.
I was wondering about , what should be considered while deciding the number of strands for coil (for the skin effect). should we consider PWM frequency or the audio frequency range?
Old 13th July 2012, 11:21 AM   #2090
Stewin tell my schem you interesting
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
