Hi Juan,
SP ERR LED works only when relay not energised (only 3 sec.)
When Q5(BS170) not conduct LED1 lit
MANOJ
oh .... ok, understand now , thank you, I will give a few more revisions of the layout, the PCB supply is quite big, I will see if I can reduce a bit more if not I do not mind this is one of my supply and is quite large = (grande) = large
Best Regards
Juan
Hello mister Manoj I think the layout is almost done can you give a check when you get chance = "time" on the schematic you send me there is another option "Optional limiter" since my PCB is quite large I think I can find some space for that circuit what part number is the LDR mister Manoj ?
Best Regards
Juan
Best Regards
Juan
smps for classe d
I received my transformer pc40 49/32/19. can i have 1500w with him for my classe d amplifier without saturating ?
NSL32 can be used or ordinary ldr with white led
thank you sir
I will search online for those options
Juan
here more updated LC meter i also made and it works well
small 100uh coil can be found on defective tv or psu
mr. you can share component layout, Thank you.
please this AUD600 amplifier heats the IR2110 IC
Using low Qg(20nC)& low Ciss with high fsw(400KHz) It will not heat up and Qg=70nC with 250KHz the same low temp (@40deg)
Qg=70nC ,Ciss=2300pf and fsw=300KHz IR2110 heat @45deg
MANOJ
MANOJ
goodnight thanks for the info
New IRS 4K5 JCOELHO File download link
New download link for the files
irs 4k5 - 4shared.com download free - 1
hi Nmoss
I'm also working the ir4k5 and Aud600. Please be patient I will post pictures & results in about 2days.
Have a merry Christmas everyone & remember JESUS CHRIST is the reason for the season.
much love Stewin Kenya
LINK EROR
My rework on IRS900D, it is a scaled down version using IRF640N fet at +-45vdc PSU. Ideal for Home HIFi . This mod is a combination of Joel and kartinos work, Thank you guys for the idea.
nice work . have you tried to put it on without speakers connected ???
..during. my test I was exchanging speaker load between a real 6ohms speaker and a dummy 8ohms resistive load...but I haven't intentionally fired it up without speakers..but if kartinos finding is correct it should then survived..
BTW in the schematic I miss to include the 4k7 Gate to Source resistor and a 15k tap to +Vdd feeding the high side.
Season's Greeting's!
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
