ucd 25 watts to 1200 watts using 2 mosfets
Old 17th June 2012, 11:22 PM   #2001
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi exflaco
greetings yes its 2500 in 4 ohms bridged and using FDA mosfets power can reach 4000 watts
"It's Better to try and fail than to never know and always wonder"
Old 18th June 2012, 04:43 AM   #2002
yehan is offline yehan  Philippines
Pls give me the clear schematic end pcb lay out of this amp..and how much the maximum supply rail. Thanks
Old 18th June 2012, 06:14 AM   #2003
manojtm is offline manojtm  India
manojtm's Avatar
Hi andrew,
can you tell me the FDA series you are used , is it FDA70N20?? and in India where i can get this. now i am sitting for reducing the THD level. IRF240 THD 3.7% @ quarter Volume gate resistor 47ohm SUPPLY@+42V -42V 5A load 4 ohms. i wanted below 1% THD.
RGDS
manoj
Old 18th June 2012, 02:06 PM   #2004
hi manojtm
greetings use FDA69N25 FDA90N20 OR IRFB26ON
warm regards
andrew lebon
Old 18th June 2012, 02:44 PM   #2005
http://www.youtube.com/watch?v=WDQcq...ature=youtu.be
3 pair dclass amp using IR2110 mosfets used IRFB260Nwarm regards
andrew lebon amp made by sir irvynejay
Old 18th June 2012, 02:48 PM   #2006
irs3kd with 2 rcf sub and 1srx =2r load - YouTube
Old 18th June 2012, 02:55 PM   #2007
luka is offline luka  Slovenia
luka's Avatar
what do we see on scope?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 20th June 2012, 09:14 PM   #2008
Maxmud is offline Maxmud
Help! who has a pcb on the bridge amplifier in the post №:1997
Old 21st June 2012, 07:35 AM   #2009
Hadighorbani is offline Hadighorbani  Iran
i see all page of this thread
please advice me to create on of the amp in 2 ohm stabel.
thanks
Old 21st June 2012, 11:08 AM   #2010
exflaco is offline exflaco  Armenia
The nex week could share the pcb ,and the components layer ,the schematics is your workhttp://files.diyaudio.com/forums/images/smilies/wink.gif
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
