Go Back   Home > Forums > Amplifiers > Class D
Old 11th June 2012, 11:38 AM   #1991
manojtm is offline manojtm  India
manojtm's Avatar
Ok..tell me if you need help in doing them so i can guide you
Hi CPX
Yes, I need your help.1. software 2. Attenuation(divider Network)3.connection
RGDS
MANOJ
Old 11th June 2012, 12:02 PM   #1992
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
CPX pls post procedure how to do that if its ok for you
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 11th June 2012, 07:51 PM   #1993
CPX is offline CPX  Romania
Set your amplifier gain to 20x and use this diver network:
Start with less than quarter volume and use 4 ohm load.Then go to 1 ohm load.
After that repeat the steps above with less than half volume divider.
That should give you a general ideea of distorsions.
For each of the four cases above run all tests given by the software,before starting any test use calibration feature to have optimum volume.
Software(it is free):
Download. Audio Rightmark
Old 12th June 2012, 01:19 PM   #1994
manojtm's Avatar
Hi CPX
Thanks get back soon with THD measure
Old 14th June 2012, 08:01 AM   #1995
Not only THD...try doing all tests in RAA.
Old 14th June 2012, 09:25 AM   #1996
Hi all
sorry for my bad english
i saw all post from 1 of 200
there was meny amp bord in site.
please advice to me on of them with 100w 2ohm empedance
thank you
Old 14th June 2012, 08:45 PM   #1997
hi my fren nirazmi,
hers is a nice bridge design
hi guys, who can give an electrical circuit and lay for this amp.
I want to build 1800 watt amplifier at 4 ohms.
Thanks in advance!
Old 14th June 2012, 09:00 PM   #1998
Hi guys, who can give an electrical circuit and the lay on the power of the post: # 1696 and link: ucd 25 watts to 1200 watts using 2 mosfets I want to build an amplifier 1800 watt into 4 ohms.
Thanks in advance!
Old 17th June 2012, 06:21 PM   #1999
yehan is offline yehan  Philippines
Help pls how much the power output for this amplifier?
Old 17th June 2012, 09:15 PM   #2000
exflaco is offline exflaco  Armenia
Triell say 2500w at 4
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
