ucd 25 watts to 1200 watts using 2 mosfets - Page 199 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th June 2012, 03:10 PM   #1981
CPX is offline CPX  Romania
manojtm:
Yellow/white cores are for dc,are not good for class D. I do not remember your pcb and why i said it is bad,but thd measurments are a must especialy if you do not have a sensitive ear,with music i can not hear alot of distorsions.
Old 9th June 2012, 03:12 PM   #1982
andrewlebon's Avatar
no this one has lm311 ne555 and bd136 for faster gate discharge
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 9th June 2012, 03:16 PM   #1983
Default triell 3200 watts ucd pcb
well i will post pcb after i make it and test it
warm regards
andrew lebon
Old 9th June 2012, 03:23 PM   #1984
SNY is offline SNY  Hungary
Default pcb
warm regards
andrew lebon
Are you sure the board works well? I see a huge ground loop .....
File Type: jpg amplificador digital de 3200 wats 08 06 2012.jpg (37.2 KB, 1083 views)
Old 9th June 2012, 03:26 PM   #1985
manojtm is offline manojtm  India
manojtm's Avatar
hi manojtm
greetings how does your yellow core not heat just finished my dclass 3 pairs
90n20 have to use 2 cores together sendust coolmu cores yellow cores dont work
hi andrew
i cannot explain in this thread. practically i made like 1.core temp reduced 2.Efficiency increased 3.DC offset locked to below 25mV 4.reduced EMI 5.MOSFET temp. reduced without heatsink it will work perfectly.now i feel 42V supply 3x MOSFET it produced more than 150W louder and it can handle 14A with cool, I tested 1.6E load mosfet temp only 48deg.c for 15min.
RGDS
Manoj
Old 9th June 2012, 03:27 PM   #1986
hi sny
greetings well this triell pcb has not been tested but it sells for 400$
well single sided pcb if well designed is not a problem for dclass amps my IR211O
WITH 3 PAIRS mosfets and zetex gate driver transistors i have no noise issues the ucd
amp has noise issues when placed in a cabinet ucd1200
warm regards
andrew lebon
Old 9th June 2012, 03:50 PM   #1987
manojtm's Avatar
cpx
i will check THD but it will take time
RGDS
Manoj
Old 9th June 2012, 05:13 PM   #1988
how much current does it consume for producing 400watts of real power?????
Old 11th June 2012, 06:55 AM   #1989
manojtm's Avatar
Hi all
I said my amp produced more than(150w)196W on 42V supply (84/3)^2/4ohm =196W
Half side current draw is 4.6A,{196x3=588W so current 14A}
RGDS
MANOJ
Old 11th June 2012, 11:06 AM   #1990
Originally Posted by manojtm View Post
cpx
RGDS
Manoj
Ok..tell me if you need help in doing them so i can guide you.
I think what you have there are yellow cores without white,probably material 6 .
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
