ucd 25 watts to 1200 watts using 2 mosfets
Old 9th June 2012, 09:33 AM   #1971
manojtm is offline manojtm  India
manojtm's Avatar
hi cpx
my old design the same problem found. what i did was 10ohm connect heatsink with GND main and all the gnd connected to main GND(signal&spk)and +&-supply through 10uH coil
RGDS
MANOJ
Old 9th June 2012, 11:25 AM   #1972
manojtm's Avatar
hi cpx
look my attch. file
Old 9th June 2012, 01:31 PM   #1973
CPX is offline CPX  Romania
Ok,thanks alot for the schematic
But what to do if i must use only one heatsink?
Old 9th June 2012, 02:08 PM   #1974
Im have seen irs2092 modules with 1 or 2 chanels with one heat sink and even no ground plane like irdaamp7 which work ok,how is that posble,is
irs2092 or pre filter feedback less susceptible to rf noise?
Old 9th June 2012, 02:30 PM   #1975
manojtm's Avatar
hi cpx
10E with 2KPf parallel connected to GND and use small ferrite with 3turns connected from main GND to signal gnd noise will reduce.
cpx my old thread i mentioned ground plane is creating problem for me but nobody supported.avoid ground plane on MOSFET & Filter side OR do not use ground plane,its my opinion other side i don't know.
RGDS
Manoj
Old 9th June 2012, 02:53 PM   #1976
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default triell amp 3200 d
triell dclass anyone have its schematic pcb can be made but some parts
can not be seen clearly
warm regards
andrew lebon
File Type: jpg amplificador digital de 3200 wats 08 06 2012.jpg (35.5 KB, 1156 views)
File Type: jpg costa do amplifiador digital de 3200 wats.jpg (289.6 KB, 1140 views)
"It's Better to try and fail than to never know and always wonder"
Old 9th June 2012, 02:54 PM   #1977
manojtm's Avatar
hi cpx
my new design (you said its BAD PCB Design) i used yellow/white core with 30Turns 16SWG wire and 3x IRFP240, core temp. is 35-38deg.c MOSFET Temp. 38-40deg.c low EMI
tested voltage with +42V,-42V DC load 5E 50W resistor stead @full volume for 1hr.
i never taken THD measure,DC offset is -18mV to -24mV.
everyone said IRFP240 & yellow/white core not good for class D. My curiosity is practically what happen in this components
IRF240 is Qg is affordable rate clamp diode not good solving this connect good diode externally,my way like this
RGDS
Manoj
Old 9th June 2012, 03:03 PM   #1978
hi manojtm
greetings how does your yellow core not heat just finished my dclass 3 pairs
90n20 have to use 2 cores together sendust coolmu cores yellow cores dont work
warm regards
andrew lebon
Old 9th June 2012, 03:06 PM   #1979
Default 2 cores together
for HIGH POWER you can see 2 sendust cores and i have made this amp clone
one core heats up
warm regards
andrew lebon
Old 9th June 2012, 03:08 PM   #1980
manojtm's Avatar
hi andrew
i think its your first schematic used with 2x IRFP250
RGDS
Manoj
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
