| Class D Switching Power Amplifiers and Power D/A conversion |
#1891 |
hi classd2008
my working proj. use 132khz hi andrewlebon ionutzxpo says correctTrr 100-200ns body diode for 250-300khz aplication |
#1892 |
manojtm Where's the schematic or project that you said put??
#1893 |
Hi
greetings thanks for the advice i am using FDA series mosfets and prototype is working very good anyway thanks all of you warm regards andrew lebon |
#1894 |
Hi all
attaching my old design again RGDS manoj |
#1895 |
Yes, it is very good for sub-amp, fsw=150 kHz, but only with disabled/replaced diode (series UltraLow Vf schottky, parallel FRED)! + pnp gate booster.
#1896 |
manojtm as this temperature for high power?
#1897 |
hello
greetings just want to ask if IR2110 candrive 2 pairs IRFP250N as i am new to class d this is a picture of 2 pairs irf250n being driven by ir2110 warm regards andrew lebon |
#1898 |
Hi Manojtm
greetings can you give correct tl431 there are so many packages of tl431 which one are you using i also need 2 ampere 12 volts fo IR2110 trying to LM2576T but i cant get 100uh inductor so i try TL431 warm regards andrew lebon |
#1899 |
Hi anrewlebon,
i mentioned on schem. R A C of TL431 |
#1900 |
Hi All
Attaching NEW DESIGN SOME PART DOTED GREEN LINE IS NOT TESTED ANY ONE NEED HIGH WATT USE IRFP23N50L WITH +140 -140 YOU WILL GET 2K2 RGDS MANOJ |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
