ucd 25 watts to 1200 watts using 2 mosfets
Old 11th April 2012, 12:39 PM   #1881
manojtm is offline manojtm  India
manojtm's Avatar
Hi Pergo
It is my design do some modification
Old 11th April 2012, 12:40 PM   #1882
luka is offline luka  Slovenia
luka's Avatar
Originally Posted by manojtm View Post
hi luka
its (-16mV) not 16mV
|16mV| is this better? it doesn't matter if it is + or -, just how big offset is, and 16mV is low... AB amp probably have more or there about
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 11th April 2012, 02:46 PM   #1883
manojtm's Avatar
Hi luka
Old 11th April 2012, 02:56 PM   #1884
manojtm's Avatar
Originally Posted by don2007ksa View Post
Hi Manojtm i used 600 khz oscillator based on your schematic my IR2110 IS DEAD,my IRF240 also dead,hope you can post your schematic with modification,thank's.
Hi don2007ksa,
pls inter change pins connect the pin 10 & 12 of the IR2110 and i never used 600KHz
Old 11th April 2012, 03:08 PM   #1885
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Hi All
tested my design its AMAZING POWER!!!!!!!!!
no noise Clear sound and good power
when i check speaker line without signal it showing -16mV this problem i want to clear ....
good jod sir....
Old 11th April 2012, 07:43 PM   #1886
don2007ksa is offline don2007ksa  Philippines
Thank's manojtm i will try another one & go back to the original OSC. hope i can make it..
Old 11th April 2012, 07:52 PM   #1887
hi CLASS2008 i'm referring to my on oscillator triangular(600 khz) using manojtm schematic but without it's 125khz square,hope you will not be misguided.
Old 12th April 2012, 02:00 AM   #1888
classd2008 is offline classd2008  Puerto Rico
Yes... manojtm use only 125Khz square to triangle signal.
Where is the schema design of manojtm?
Old 12th April 2012, 02:00 AM   #1889
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
HELLO
greetings is this mosfet a good choice for high power d class amps
IXFH88N30P
warm regards
andrew lebon
Old 12th April 2012, 06:18 AM   #1890
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
hi andrew,gate charge and capacitance to high, IR2110/13 will run hot ,it might work but at 100Khz for bass only high power amp
search for 2-3nF and a maximum 60-70nC capacitance and gate charge,Trr 100-200ns body diode for 250-300khz aplication
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
