| Class D Switching Power Amplifiers and Power D/A conversion |
#1861 | |
Have you tried cakeamp too?
There is always a first time.... |
#1862 |
hi guys is this fet good with this amp irfb4229 at +/- 90vlts at 2ohms ?
#1863 |
Hi all
tested my PCB(3x IRFP240). Its working good.some modification made i will post my schematic soon |
#1864 |
#1865 |
Do you have any alternative or similar to compare with ?
![]() I think no , so use 'em , they'll do. |
#1866 |
they are the only good high voltage fets i have found so far than irfb23n20
#1867 |
stewin,
23n20 has the breakdown voltage of 200V , they aren't good for +\-90V application . So as the other 200V mosfets ! 4229 has 250V breakdown . |
#1868 |
Hi Manojtm i used 600 khz oscillator based on your schematic my IR2110 IS DEAD,my IRF240 also dead,hope you can post your schematic with modification,thank's.
#1869 | |
#1870 |
Hi Stewin what schematic you're using?can you share it?thank's.
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
| Page generated in 0.10728 seconds (100.00% PHP - 0% MySQL) with 10 queries |
