ucd 25 watts to 1200 watts using 2 mosfets
Old 15th March 2012, 02:40 PM   #1821
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Originally Posted by manojtm View Post
companies CROWN & Crest Audio they are not supporting self osc UCD for PA application
RGDS
Manoj
Well no, I'm sure they are not. Are they prepared to pay Philips/NXP for a UCD licence, or to comply with Philips/NXPs requirements for licence-free use of the technique?
Old 15th March 2012, 07:05 PM   #1822
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by CPX View Post
you can still test your amplifier by using substraction.
Yea , something like that , first need to make a good pre-amp , because my amps have gain=10 , the output of the soundcard is'nt enough.
Old 15th March 2012, 07:16 PM   #1823
Dimonis's Avatar
Self osc. UCD is not good for Higher WATT (above 200W).It will create lot of problems
ie. Heat,Noise & high Start up Current
WOW above 200W
And that do you recommend ? What type of feedback?
Old 15th March 2012, 07:41 PM   #1824
Dimonis's Avatar
normally we are using osc=300 KHz for good THD Better for 500 KHz
from LM4651 & 4652 Notes .
Why you can't understand THD not only depends on frequency , more on deadtime.
Old 15th March 2012, 07:42 PM   #1825
CPX is offline CPX  Romania
Dimonis... self osc ucd can give 10kw if you want.
Make some tests without preamp..use my gain 10 2/3 power divider schematic that i posted a while ago.
Old 15th March 2012, 09:11 PM   #1826
Dimonis's Avatar
I don't doubt , tell this manojtm
Old 16th March 2012, 12:00 AM   #1827
norazmi is offline norazmi  Malaysia
absolutely right, CPX can u post again optimum pre-amp for ucd? i want to improve gain with my discrete ucd , wanna see if there is lot improvement with preamp and without it, i`ll report the result here after..
thanks.
Old 16th March 2012, 12:00 AM   #1828
u already told him many time before,
Old 16th March 2012, 12:04 AM   #1829
pssttt... Dimonis, wanna see video exercusion test with parallel mosfet again? hihi
Old 16th March 2012, 07:18 AM   #1830
manojtm is offline manojtm  India
manojtm's Avatar
Hi all
sorry for troubling all of you
thanks CPX & Dimonis
word from Apex :
We always must made so many compromise, and never made best amplifier we can. Never can be made best amplifier, nothing is perfect.
RGDS
Manoj
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
