Go Back   Home > Forums > Amplifiers > Class D
Old 14th March 2012, 01:53 PM   #1801
manojtm is offline manojtm  India
manojtm's Avatar
Hi Dimonis
increase gate resistor with correct value , decrease temp.
normally we are using osc=300 KHz for good THD Better for 500 KHz
I use osc=125 KHz it is not BAD and filter 4th order one
RGDS
Manoj
Old 14th March 2012, 06:14 PM   #1802
Hi manojtm about your UCD 625,your oscillator there is about 102 khz square wave,what if i'm going to use around 500 khz triangular wave? are there any part's to be changed? is it possible for me to use this amp for full range @ 4 ohm's load,thank's.
Old 14th March 2012, 06:47 PM   #1803
stewin is offline stewin  Kenya
nice work cool video .BTW the fets in your video are they irfp250 2pairs?
Old 14th March 2012, 08:42 PM   #1804
norazmi is offline norazmi  Malaysia
Yep Stewin, irfp250n, they run happily with it
Old 15th March 2012, 05:00 AM   #1805
manojtm's Avatar
hi don2007ksa
don't go for 500Kz , thd+n will increase better for 250 or 300khz
Old 15th March 2012, 06:18 AM   #1806
manojtm's Avatar
don2007ksa
use cd4060 with 8MHz crystal
Old 15th March 2012, 07:26 AM   #1807
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
-increases the switch times of the mosfets(rise & fall) - increases the deadtime - increases the THD .
For the subamp application it'll do , but for the full range......
Yea , at that freq you can bravely use 2-3 pairs of mosfets (4227)
What driver & mosfet?
And about THD - how much better ? maybe you'll post some ?
Old 15th March 2012, 09:27 AM   #1808
Dimonis's Avatar
Hi CPX
Originally Posted by CPX View Post
I am using RightMark Audio Analyzer 6.2.3(free version) and Acoustic Analyzing System 5E(THD only), they give similar results.
My soundcard (built-in on motherboard Intel DP35) has such results (measured line-in-line-out) . I think they are not good enough for measurement?
And my netbook has awful noise ~56dB and IMD ~0.5%
Can't find Acoustic Analyzing System 5E , can you share it with me?
Old 15th March 2012, 09:44 AM   #1809
Dimonis's Avatar
Hi don2007ksa
Originally Posted by don2007ksa View Post
Dimonis i have 60 hertz,+/- 90 VOLTS @ 800 watts power transformer,i'm going to used a 4 ohm's load around 700watt's full range speaker,thank's.
I think the best solution is the amp from this thread
http://www.diyaudio.com/forums/attac...ir2110_ucd.zip
Old 15th March 2012, 01:44 PM   #1810
manojtm's Avatar
Hi dimonis
Self osc. UCD is not good for Higher WATT (above 200W).It will create lot of problems
ie. Heat,Noise & high Start up Current
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
