ucd 25 watts to 1200 watts using 2 mosfets - Page 179 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th March 2012, 10:57 AM   #1781
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
so does it means using irfb4227 is not good choice for ir2110/2113?
Sorry for asking im just newbie on this class d thingy
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 12th March 2012, 11:54 AM   #1782
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Only single , not parallel , don't exceed 300kHz running frequency.
Better 2xIRFB5620 in parallel ~= 1xIRFB4227
Old 12th March 2012, 12:10 PM   #1783
irvynejay's Avatar
thanx Dimonis for your guidance
Old 12th March 2012, 06:50 PM   #1784
norazmi is offline norazmi  Malaysia
nice goind Irvy , did u put any protection for your full bridge version? ovp, uvp, ocp?
Old 13th March 2012, 01:42 AM   #1785
irvynejay's Avatar
thanx norazmi,,no any protection you can share for newbies ?
Old 13th March 2012, 04:45 AM   #1786
yup why not , i`ll put schema here for the protection, take it from iraudump 7D OVP, UVP and OTP, for short circuit we can use ne555 timer u can take it from classdfromru website refer to ucd2.5 .
Old 13th March 2012, 05:37 AM   #1787
andrewlebon's Avatar
Default PROTECTION SCHEMATICS
Hi Norazmi
greetings that would be nice protection schematics
warm regards
andrew lebon
Old 13th March 2012, 07:29 AM   #1788
here is the schema, D1 is zener diode to set maximum voltage for your amp, and D2 is zener diode to set minimum voltage for your amp. TH001 thermistor 2.2k directly put on heatsink for thermal protection.
Old 13th March 2012, 07:33 AM   #1789
manojtm is offline manojtm  India
manojtm's Avatar
Hi All
The importance of the gate charge data to the designer is illustrated
as follows. Taking the charge are required to switch a previous
example, about 15 nanocoulombs of gate if 1.5 amps is supplied to the
gate, the device will be drain voltage of 80 volts and a drain current
of 12 amps. Since the 15 nC gate charge is the product of the gate
input current and the switching time, switched in 10 nS. It follows
that if 15 mA is supplied to the gate, then switching occurs in 1 us,
and so on. These simple calculations immediately tell the designer the
trade-offs between the amount of current available from the drive
circuit and the achievable switching time. With gate charge known,
the designer can develop a drive circuit appropriate to the switching
time required.
Consider a typical practical example of a 100 kHz switcher, in which
it is required to achieve a switching time of 100 nanoseconds.The required gate drive current is derived by simply dividing the gate charge, 15 X 10
-9
, by the required switching time, 100 X
10
-9
, giving 150 mA. From this calculation, the designer can further arrive at the drive circuit impedance. If the drive circuit
applies 14 volts to the gate, for instance, then a drive impedance of about 50 ohms would be required.
Link: http://www.electro-tech-online.com/c.../08/an-944.pdf
Manoj
Old 13th March 2012, 08:01 AM   #1790
manojtm's Avatar
Hi all
thanks to the ref.
IR2110 can drive 2nos of IRFP250N(Qg=140) 3nos of IRFP240 & IRFP4227 (Qg=70 minimum)
Manoj
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 91 16th December 2016 04:56 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
