| Class D Switching Power Amplifiers and Power D/A conversion |
#1761 |
#1762 |
Dimonis :
They require kwatts and full audio band ...personally i am interested in getting my amplifier THD and IMD lower...but since no one makes those tests i have no help in this matter .norazmi: What residual amplitude do you have? |
#1763 |
#1764 |
#1765 |
cpx , ive download the program u told me, and i need time to learn coz too many setting and option, ill try to learn it as fast as i can. Btw what exactly cause filter caps become hot? Too high freq?
#1766 |
norazmi:
To much esr...and too much disipation when testing with high voltage and high frequency output, with no input signal and normal oscilation you shoud have no heating. To use that software you need to make an output divider and filter.I made some very aproximative calculations.. . but i hope it helps.
#1767 |
hello can ask some thing is it possible to use irf3710 ,IRF3808,IRF2807 for class d amps?
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend |
#1768 |
Hi All
CPX you are doing a wrong method Desktop computer already have noise(More compare with Laptop) , so how you measure THD+N???? |
#1769 |
Hi All
Class D AMP using second order filter so ie. L=(.225*RL)/Fc Fc is cutoff freq.;Cut off freq. is the final out put so just tell me the THD+N you measure from where? with cut off freq. or without Regards Manoj |
#1770 | |
![]() Noise have all equipment , best audiocards for desktop comps have about 0,001% THD+N , don't think that you diyamp is somethink equal .
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
