ucd 25 watts to 1200 watts using 2 mosfets
Old 8th March 2012, 04:56 PM   #1731
norazmi is offline norazmi  Malaysia
Thanks CPX
Old 8th March 2012, 05:15 PM   #1732
CPX is offline CPX  Romania
We're welcome.
You can even use ultra low noise opamps if you find you ucd noisy,decrease lm311 gain to 5x and increase its supply rails to +-15v and use this modified circuit to obtain total gain 25x with global noise much better than with standard lm311 with gain of 25.
Old 8th March 2012, 06:35 PM   #1733
ok, i`ve some issue when up the gain of the op-amp, it will distort the input signal if the gain is too much even at low volume, so i think need to find out the maximum gain can be accepted for each amp, 25x gain lol its too much i think, but i like ultra low noise.
regards.
Old 8th March 2012, 07:12 PM   #1734
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by CPX View Post
We're welcome.
What relationship between supply and gain?
Optimal gain is about 10.
Old 8th March 2012, 07:32 PM   #1735
Yes gain 10 is good..but snr is better with gain decrease if you use a ultra low noise op amp befere ...
If you decrease gain you have to increase lm311 supplies to avoid clipping..for gain 10 and +-12 volt suplies you can have maximum 60 volt rms output,for gain 5 you can have maximum 30 and so on...for gain 5 and +-6 volt you can have maximim 15..etc
Old 8th March 2012, 09:32 PM   #1736
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default bridging ucd amplifier
Hi Cpx
greetings thanks for sharing schematics
warm regards
andrew lebon
Old 9th March 2012, 06:32 AM   #1737
manojtm is offline manojtm  India
manojtm's Avatar
Hi All
Just posting My New Design PLS check any correction have ,noted
Old 9th March 2012, 06:49 AM   #1738
Dimonis's Avatar
I see , clipping occures on the input , not at the output
I'm using the inverting kind of input , hence i'll dont get any clipping even at low supply.
Old 9th March 2012, 07:27 AM   #1739
Default HELLO
Hi Manojtm
greetings whats power of amp at 80 volt dc supply and is it suitable for 2 ohms load nice work
warm regards
andrew lebon
Old 9th March 2012, 08:38 AM   #1740
manojtm's Avatar
thanks
RMS 710W @ 4ohm
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
