Go Back   Home > Forums > Amplifiers > Class D
Old 29th February 2012, 03:54 PM   #1701
CPX is offline CPX  Romania
Dzony988 ..you shoud have no bus pumping in bridge mode.
Unfortunately No One makes real tests..i asked several times for some distorsions tests in vain...
Also i am interesested how you have implemented your protection schemes..the amplifier has to survire a short to output or rails, also over power in hard clipping,excesive bus pumping at 10-20hz and very high currents(>20A) ...simply sensing peak currents is not enough.
Old 29th February 2012, 05:16 PM   #1702
stewin is offline stewin  Kenya
hi cpx .what can be done to avoid bus pumping and the above?
Old 29th February 2012, 05:34 PM   #1703
Alot can be done..and i am still doing experiments.
I have around 10-15 volts bus pumping at 20 hz so probably this in not the reason my fets burn at 25A,but reducing capacitance from 10mF to 5 mf makes them burn at only 8A rms,so bus pumping may not be the problem...increasing capacitance to 15mf and adding a high pass filter will probaly solve this...
Hard clipping is another story..when hard clipped before peak current the peak current protecion will not work since is not measuring rms.A rms to voltage should be used but the conversion is to slow for efective protection so i will try implement an aditional rms current protection.
Also a clipping current limitator can be implemented but that will not save the amplifier if it is fed with a square wave.
Old 29th February 2012, 06:01 PM   #1704
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by Dzony988 View Post
Only problem with full bridge is very high current and bus punping.
You mean pumping ?
In full bridge there"s no bus pumping
Old 29th February 2012, 06:08 PM   #1705
Originally Posted by Dimonis View Post
You mean pumping ?
It may be if the bridge is unbalanced by using different switching frequencies between amplifiers creating unequal gain,but should be negligible .. 1 or 2 volts.
Old 29th February 2012, 06:40 PM   #1706
Dimonis's Avatar
CPX
Agree with you.
But that"s not a good bridge
And i doubt about switching freq.
Old 29th February 2012, 06:57 PM   #1707
CPX
Agree with you.
In mixed mode operation(stereo - bridge) you need to have different switching speeds and gains.
Old 29th February 2012, 07:37 PM   #1708
Dimonis's Avatar
Ok. I understood about switching frequences , but why must the gains differ?
Old 29th February 2012, 07:42 PM   #1709
Different switching speeds generate diferences in gain also in this ucd..i was unable to change gain and switching frequency indepenend on each other.
Old 1st March 2012, 06:54 AM   #1710
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
Hello can i ask some newbie question could i use this mosfet on class d amp
IXFX30N100Q2 and IXFH15N80
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
