ucd 25 watts to 1200 watts using 2 mosfets - Page 170 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th February 2012, 12:05 AM   #1691
andrewlebon's Avatar
Default ucd 1200
Hi Sameerx1
nice pcb good to have dc protector pcb has holes for IRF250 and
IRFB4227PBF
WARM REGARDS
andrew lebon
Old 28th February 2012, 07:40 AM   #1692
akraj is offline akraj  Bangladesh
Default JBL Class D amp for Subwoofer!
Dear All:
I am planning to devlop a PCB of the attached Schematic, this is from JBL sub.
I know there are more simpler schematic out there but just thinking that this is well tested and all soft of protections are there.
Any comments not to do this? Thanks in advance to all.
https://www.cx.com/mycx/share/PYYgQ0...i_%5BET%5D.pdf
Raj
Old 29th February 2012, 01:02 PM   #1693
For Andrewlebon
you can use any two amps for bridge with this! Amps must be the same as much as possible.
I use this schematic for this ucd amp. On out+ goes in of first amp and on that amp you conect + of speaker. On out- goes in of second amp and on that amp you conect - of speaker.
And that is all about full bridge. With this amplifeir this is very good schematic because in inputs of both amps you have op amps who is low impedance soruce of signal, that means you can use 4.7nF cap from input to gnd and you have low noise and full audio range. Before input (in1) on bridge adapter, I recomanded you 4.7K lin pot for volume!
All is power with +-15V
Old 29th February 2012, 01:11 PM   #1694
If you build classic amp with two chanel, you can use my "Volume panel".
With this panel you have volume control for both chanel and easy can swich all amp in full bridge mod with bridge swich. When bridge is on, Led is turned on..
All is powered with +-15V and when is whole amp in bridge mod, then you use Ch2 pot for volume control
6 pins double swich that I use for this. It's no metter side of conection, only is metter conection of swich PARALEL to pins on pcb (like the swich is on top of pcb, if you understand me).
Now you'll know when is bridge mod turned on because led will turned on too.
Old 29th February 2012, 01:53 PM   #1695
norazmi is offline norazmi  Malaysia
Dzony absolutely right, i already told him about it, use 2 amp pcb to make it bridge. Provided u need big PSU and enough current to get full power. +/- 50 vdc is enough in full bridge. Btw Dzony already posted bridge circuit and pcb, nice work.
Old 29th February 2012, 02:10 PM   #1696
hi my fren nirazmi,
hers is a nice bridge design
Old 29th February 2012, 02:13 PM   #1697
Lol
Your pcb worked? How does it sound? tell me about noise also.. if u have time
Old 29th February 2012, 02:26 PM   #1698
Full bridge is good for subwoofers in class D, because half bridge dont have strong "bum" bass . Only problem with full bridge is very high current and bus punping. Lots of capacitance needed in PSU to avoide bus pumping in rails and if you drive 4ohms speaker in full bridge, both of amps sees half of whole impedance = 2 ohms per amp...
What do you think, can IRFP250 run in full bridge on +-70V and 4ohms load?
I drive IRFP240 on +-50V and 4 ohms full bridge and everuthing is ok but mt transformer dont produce big current and before cliping in subwoofers I can hear big dostrosion and mechanical sound
Old 29th February 2012, 02:33 PM   #1699
IRFP250N yes why not, if you dont mind about thd. u need to setup proper gate resistor for it or u will need big heatsink
i did before full bridge with irf540N with 2 board and drive 6 15 inch speaker hard at carnival college start run 8:00 pm till 2:00 am, and its survive hehe voltage = +/- 48.9 vdc, 1 uf caps at each amp and 22 uh T106-2 no problem.
Old 29th February 2012, 02:36 PM   #1700
Dzony with original pcb mr ejtagle i dont face any bass pumping even in full bridge. Filter ur power supply with good filtering, 1uf 250 vdc at +vcc to gnd, -vee to gnd and +vcc to -vee. Mine use 6 1 uf 250vdc.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
