ucd 25 watts to 1200 watts using 2 mosfets - Page 166 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st February 2012, 12:03 PM   #1651
CPX is offline CPX  Romania
Define""to bright". In my experiments i found frequency response to be pretty liniar(+-1.5 db 20hz-20khz) with 8uH inductor and 300 khz switching...
Old 21st February 2012, 12:39 PM   #1652
opor is offline opor  Thailand
Originally Posted by opor View Post
With C17 is 150pF.
I mean sound is harsh .
Old 21st February 2012, 01:13 PM   #1653
Define "sound is harsh".I do not understand such staments...i need measurable parameters.
Maybe you have to much distorsions...try to measure THD and IMD...
Old 22nd February 2012, 12:51 AM   #1654
andrewlebon's Avatar
Default mosfet
Manufacturer Part #:
FDA69N25
Manufacturer:
Fairchild Semiconductor
Description: MOSFET 250V N-Channel MOSFET
Silverlight Page 2,739, Mouser Enhanced Catalog
PDF Page 2,739, PDF Catalog Page
PDF Data Sheet
Images are for reference only
See Product Specifications
Customers Also Bought...
Specifications
Documents
My Notes
Manufacturer: Fairchild Semiconductor
Product Category: MOSFET
RoHS: RoHS Compliant Details
Transistor Polarity: N-Channel
Drain-Source Breakdown Voltage: 250 V
Gate-Source Breakdown Voltage: +/- 30 V
Continuous Drain Current: 69 A
Resistance Drain-Source RDS (on): 0.041 Ohms
Configuration: Single
Maximum Operating Temperature: + 150 C
Mounting Style: Through Hole
Package / Case: TO-3PN
Packaging: Tube
Fall Time: 220 ns
Minimum Operating Temperature: - 55 C
Power Dissipation: 480 W
Hi
greetings can this mosfet be used in ucd 1200 as IFB4227 hard to find here
warm regards
andrew lebon
Old 22nd February 2012, 01:03 AM   #1655
andrewlebon:
It has a huge Reverse Recovery Charge(5700nC),you wll se very big comutation spikes and EMI.
You never reponded to my last PM..
Old 23rd February 2012, 12:32 AM   #1656
@stewin , opor
hi guys here is my new bridge class dClick the image to open in full size.
Old 23rd February 2012, 12:39 AM   #1657
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
Good job Gerry go go go go pinoy
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 23rd February 2012, 12:41 AM   #1658
ready to test
Old 23rd February 2012, 01:22 AM   #1659
hello gerry_morales
look good .
I am interested also...
Old 23rd February 2012, 04:36 AM   #1660
Hi, gerry_morales. Look nice. How about sound?
I am trying to modify mine because it seems too harsh compare to AB amp.I have not any measurement device but my ears.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
