ucd 25 watts to 1200 watts using 2 mosfets
Old 9th February 2012, 08:58 PM   #1621
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by andrewlebon View Post
cant get
t106_2 core here so i cant really tell what core will sound best can any one suggest where i can order t106_2 prewound 33uh inductor
warm regards
andrew lebon
Amidon in the states have t106-2 core. I alos picked some up on ebay.
I just wind a couple of metres of 18swg enammeled copper wire around the core. Its a fiddle but isnt too bad.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 9th February 2012, 10:48 PM   #1622
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default THANKS FOR REPLYING
Hi Nigelwright
greetings thanks for replying i think amidon is my only hope to get best core t106_2 most suitable for this amp thanks once again
warm regards
andrew lebon
Old 9th February 2012, 11:07 PM   #1623
Default thanks
Hi Stewin
greetings at last got it working dont have any issues on amp working
its playing great clear and powerful the pcb i posted looks bad its the first pcb on the thread after many failed attempts ifigured out how it should be assembled without blowing up parts trying to make a bridged version designing
the PCB will be a problem no PCB experience but ill try can you share any bridged schematics using IR2110 I will use IRFB4227 for outputs btw whats working frequency of this amp have you experimented with feedback 330pf
cap schematic says mica i have used 330pf ceramic 1kv i have 330pf silver mica
would changing the ceramic to silver mica make sound more clear not tried is as yet hope you can share your results
warm regards
andrew lebon
Old 10th February 2012, 09:36 AM   #1624
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by stewin View Post
try to get e cores from old pc power supply and boil them in hot water . after separating them coil 30 turns and make sure you add 1mm gap using a tiny piece of old cd or dvd disc. .
A good thing , but the gap must be larger - something about 2mm , or 4mm in the center leg.
Old 10th February 2012, 02:57 PM   #1625
Default FEEDBACK CAPACTOR 330pf
In the feedfack, try to change capacitor C1 (330p, mica) to 150p or 100p (you can use ceramiic or anything). This should turn your switching freq from 120kHz to about 200-230kHz. This would improve filtering from 20dB to about 30dB.
Hi
greetings will changing C1 330pf to 150 pf on 50 volts dc supply work on my ucd outputs IRF250N OTHERWISE all components are same as schematic given
by egtagle
warm regards
andrew lebon
Old 10th February 2012, 09:36 PM   #1626
stewin is offline stewin  Kenya
why large gap like 4mm
Old 10th February 2012, 10:41 PM   #1627
Pafi is offline Pafi  Hungary
If you want 1000 W, then fsw should not exceed 200 kHz. Then L>40 uH is advisable to achieve low idle loss. Since 100V/3 ohm (current headroom needed!) = 33A, E>22 mJ. Energy density in gap at saturation is about 40 mJ/cm^3, so at least a half cm^3 is needed for this much power. A=1.2...1.5 cm^2, so d=4 mm is a good estimation. But leakage is horror! I use 4 mm also, but in EE55 (A=3.5cm^2, L=80 uH), so it's safe and perfectly cool.
But for only 50 V and 4 ohm, 1 mm gap is OK!
Old 10th February 2012, 11:51 PM   #1628
norazmi is offline norazmi  Malaysia
Agreed with Pafi
Old 12th February 2012, 12:42 PM   #1629
thanks pafi GOD bless you a lot
Old 15th February 2012, 07:55 AM   #1630
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi All
Now I will give my working design!!!!!!!!!!!!!!!
Its simple and good.Protection and all other things can added later
Hi Manoj:
Electronics is my hobby and mostly excited for amplifiers, I am trying to make a class D amp using your schematic. Now can you please tell me what is meant with (SD) sing (Pin 11 of IRS2110)? And can I find the inductors in the market?
Here is the link of PCB: https://www.cx.com/mycx/share/kBI-n1.../UCD_India.pcb
Not finished yet, need to improve tracks.
Thanks in advance.
Raj
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
