ucd 25 watts to 1200 watts using 2 mosfets
Old 6th February 2012, 02:57 PM   #1611
savu is offline savu  Ireland
savu's Avatar
Send a message via MSN to savu
IRFB4227 is best suited. You can use rails as high as 90v.
Savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 6th February 2012, 04:19 PM   #1612
CPX is offline CPX  Romania
For andrewlebon :
irfb4227.Also try irfb5615
For manojtm .
Please measure THD and IMD of your design and post results here if you can.
Old 6th February 2012, 06:17 PM   #1613
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by andrewlebon View Post
Hello
greetings can any one advice me which is most suitable mosfet for this amp
i am using IRF250 on50 volt dc rails
1 IRFB4103Pbf
2 IRFB 4227BPbf
data sheet of IRFB4103 shows Rds on@10 volts 139Mohm
data sheet of IRFB4227 shows Rds on@10 volts 19.7Mohm
can anyone advice me most suitable mosfet
warm regards
andrew lebon
Catch
It's for rail up to +-65V
The "lightest" , I.e. prefered from the top.
Old 6th February 2012, 06:26 PM   #1614
Dimonis's Avatar
If you desire up to 90V per rail
These will suite well.
Old 7th February 2012, 04:01 PM   #1615
Dwenson is offline Dwenson  Philippines
Send a message via MSN to Dwenson Send a message via Yahoo to Dwenson
Originally Posted by stewin View Post
no i did not use clipping indicator but i am going to do so .on the over temp issue i used a 0.1 ohm resistor when i connect it the led does not light but when i disconnect it the led lights and relay does not go off . here is my part of the schema
whats the use of J10? when R34 and c39 are in parallen to ground? have you tested it on actual run?
Old 8th February 2012, 02:35 AM   #1616
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default FINALLY WORKING
Hi
greetings can anyone guide me as its only my second sucessful d class amp
at last managed to make amp work outputs are IRF250N my supply is 50 volts
dc amp is sounding clear and powerful in 4 ohms load only problem is my output inductor after testing about 20 different cores finally managed to get cores which are luke warm on high volume testing on trying different cores of same
material with more and less turns sound quality changes more treble another core more bass how do i know which is best output inductor for me i cant get
t106_2 core here so i cant really tell what core will sound best can any one suggest where i can order t106_2 prewound 33uh inductor
warm regards
andrew lebon
Old 8th February 2012, 09:59 AM   #1617
Whortless is offline Whortless  Turkey
Whortless's Avatar
Hi
warm regards
andrew lebon
There is something wrong in your application. This is not an ordinary ClassAB amp. Therefore you must not use wires from PCB to output mosfets. First correct this and mount the mosfets directly to PCB and then try your different output inductors again. There should be some difference. It is very difficult to say which inductor is best without any measured result.
BR
Old 8th February 2012, 11:33 AM   #1618
Default THANKS FOR REPLYING
Hi Whortless
greetings thanks for replying wires are for testing all suitable mosfets available with me till i get my IRFB4227 MOSFETS
warm regards
andrew lebon
Old 8th February 2012, 12:18 PM   #1619
Dimonis's Avatar
Hi
warm regards
andrew lebon
The cores that i see at your foto seem to be ferrite?
It's not good to make inductors on ungapped ferrite.
You can make a gap in a Ring-core with a grinder , some thing about ~3mm . So it woudn't saturate.
Like this
Old 9th February 2012, 08:52 PM   #1620
stewin is offline stewin  Kenya
Hi
warm regards
andrew lebon
congrats andrew finaly you have it working. try to get e cores from old pc power supply and boil them in hot water . after separating them coil 30 turns and make sure you add 1mm gap using a tiny piece of old cd or dvd disc. BTW cool car stereo sony gt490
sad for me after like 4 months of my amp working it failed but i think it is tip 41 which supplies 12vlts to ir2110 which failed and caused the whole thing to collapse i was using 24ohms 3speakers each 8ohm speakers in series .
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
