ucd 25 watts to 1200 watts using 2 mosfets
Old 13th January 2012, 11:09 AM   #1591
fibko is offline fibko  Slovakia
I used E20 core with winding 1:1 and induction was approximately 2mH without air gap. I used the default current protection.
Old 15th January 2012, 12:52 PM   #1592
stewin is offline stewin  Kenya
hi fibko just wondering does using the tansformer gate drive yield more power or has any advantage over using chips like ir2110 .?
is the overcurrent sense working perfectly? if it is working is there a need of adding protection in the amplifier?
Old 15th January 2012, 01:28 PM   #1593
Old 16th January 2012, 06:02 PM   #1594
CPX is offline CPX  Romania
Heloo to everybody and Happy New Year!
I'm back with new problems.Now i am using lt1016,the rest of the circuit is the same.I am getting more distorsions than with lm311.
Adding capacitance between in- and in+ decreases them(30-200pF) but this means i am using a faster comparator for nothing because it just decreases its speed.
Old 17th January 2012, 01:33 PM   #1595
manojtm is offline manojtm  India
manojtm's Avatar
Hi every one
I think change the gate resistor to 100 ohm for IRF250N and connect one more filter ( first filter 55uH and second one 30uH).Now the noise will out.
Old 18th January 2012, 11:32 AM   #1596
akraj is offline akraj  Bangladesh
Hello: This is Raj and I am new to this forum. I am also interested to make good Class D amp and searching for this I saw one of JBL LS120 subwoofer's schematic. They use class D which is simple and surely will produce good sound.
Schematic is available here: Keres? - Service Manual finder | ElektroTanya | Service manuals and repair tips for electronics experts
Any expert opinion about this?
Raj
Old 18th January 2012, 12:25 PM   #1597
I can not find the manual.Please post the schematic directly.
Old 19th January 2012, 04:31 AM   #1598
Hi CPX: The file size is just over 2mb, so cannot post here. I can mail to you if you share me your address.
Old 19th January 2012, 05:13 AM   #1599
Please check the link, hope you can view:
https://www.cx.com/mycx/share/PYYgQ0...i_%5BET%5D.pdf
Raj
Old 19th January 2012, 09:38 AM   #1600
Ok..i looked at it..but the basic schematic on this forum is much simplier...,also what you have will not work full range without modifications.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
