ucd 25 watts to 1200 watts using 2 mosfets - Page 159 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th December 2011, 11:14 PM   #1581
If you conect in short pins for KTY sensor, protection shuld turn of raley.. Maybe your sesnor is not good..
Do you try cliping indicator with AN6884? (top of schematic)
Old 17th December 2011, 08:15 AM   #1582
stewin is online now stewin  Kenya
no i did not use clipping indicator but i am going to do so .on the over temp issue i used a 0.1 ohm resistor when i connect it the led does not light but when i disconnect it the led lights and relay does not go off . here is my part of the schema
Old 17th December 2011, 04:28 PM   #1583
You have two mestakes because of me ) sorry for that
R57 have to be 47ohms not 47K
and R54 have to go on base of T5 not to emitter
C39 stays where he is bettwen R54 and ground with inverted polarity because of negativ voltage after D17
Sorry, my mestake
Old 17th December 2011, 04:37 PM   #1584
Here you are original schematic...
if you interested, i can send you and over current prot
Old 19th December 2011, 12:27 AM   #1585
Default output inductor
Click the image to open in full size.Click the image to open in full size.
guys here is an example of output inductor use in class d amp
Old 7th January 2012, 08:40 AM   #1586
fibko is offline fibko  Slovakia
almost complete
Old 7th January 2012, 09:42 AM   #1587
lorylaci's Avatar
Send a message via MSN to lorylaci
Good work fibko! Looks very nice!
Olyan nem volt még, hogy ne lett volna valahogy
Old 10th January 2012, 04:33 PM   #1588
wow nice work how many watts is the smps?
Old 12th January 2012, 09:21 AM   #1589
It is 1kW SMPS (2 ​​kW peak). Inspiration comes from K6 amplifier K6 700 Watt Audio Amplifier and Switching Power Supply with a few changes and own design pcb.
Old 12th January 2012, 04:33 PM   #1590
did you use t-106 26 for transformer gate drive? did you include the over current protection in the smps?
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
