ucd 25 watts to 1200 watts using 2 mosfets
Old 19th July 2010, 02:18 PM   #141
lycanlk is offline lycanlk  Sri Lanka
Default Hi luka,
Originally Posted by luka View Post
what? last guy said it doesn't. Do you really want to find that for yourself too?
look at post #95 to #105..
and I have gone through a couple of your threads, Luka.. you are very good in this subject so please share what you have with this
regards,
Lycanlk
Old 19th July 2010, 02:26 PM   #142
luka is offline luka  Slovenia
luka's Avatar
its not the schematic that is the problem(probably), its the board, you can make Damp to work just with any kind of build and it will work at low powers... but at high is where you can have problems...
Mine work ok, for low volumes, up to say 100w... but board was just too bad for any higher power, and it didn't matter if I had 2R to 8R loads, or +/-30 to 60v for supply... I think this is the same there
If not prove it and help andrewlebon
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 19th July 2010, 02:52 PM   #143
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi savu
greetings want to ask you if the schematic really works if the circuit is ok please tell me as i am attempting d class for first time not very sure why no
output
1 voltage plus70 0 70 negative used series bulb
2 modified it like opor said changed ir 2110 4 times no one seems to have tested it at full voltage even read all pages at foros de electronica
3 any voltage readings of your amp
can you help me
thanking you
andrew lebon
Old 19th July 2010, 02:58 PM   #144
hi luka
greetings have you made this amp if so what voltage did you feed it
thank you for your thought very kind of you
thanking you
andrew lebon
Old 19th July 2010, 02:59 PM   #145
luka's Avatar
no not this one, "my" is diffrent
I FEEL SLOVENIA
Old 19th July 2010, 03:31 PM   #146
Default Ok i'm gonna build with my own design..
I'm not a good PCB designer.. anyway it is worth to try building this amp as it is so simple.. and thanks for the idea dear Luka.. if the schematic is fine then I can check out with different layouts..
I'll keep the space for any pro designers to make it while i'm trying my own..
regards,
Lycanlk
Old 19th July 2010, 04:52 PM   #147
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
Hello all,
A friend of mine built this amp:
first try was "up in smoke"
he redesigned the PCB and built it again.
it works but it has some distortion problems when connected to anything else but a portable MP3 player.
the voltage is only +/- 28Vdc because i have to build him a smps and i haven't kept my part of the deal because of lack of time.
Now i have the time to make the smps and i also intend to make this with smd components and smd switching fets. the link below is my thread using rasmir's schematic.
http://www.diyaudio.com/forums/class...et-classd.html
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 19th July 2010, 05:16 PM   #148
tacatomon is offline tacatomon  Mexico
Here are some technical data given by the author on the design of the amplifier UCD.
Distortion 0.01% to 50% power (for a 600W amplifier, a maximum of 1200W).
Low distortion even if it uses less power. And the measurement of distortion that I give is for any frequency in the audio band, from 20Hz to 20kHz! (Cleared, because many distortion amplifiers are only 1kHz, 10kHz but is much larger. It is not the case with this amp)
Output Noise: 30uV approx.
Output impedance: Of the order of 20 milliohms, or better (depending on the mosfets used)
Power Bandwidth: 0 to 23kHz (-3db) (that is to get maximum power, but the amplifier reaches much higher frequencies, just not at full power)
Voltage gain: Simply, reaches maximum power 2Vpp input signal.
Supply ripple rejection: Better than 65dB (again, depends on the components, assembly, etc)
Efficiency: Close to 92% or even less (although, again dependent on the mosfets. Probably better than the 92% for smaller powers to 1000W)
The IMD (intermodulation product is also low, with 2 modulating 19kHz and 20kHz tones, intermodulation spurious signals are smaller 80db ...
Greetings!
See You On The Other Side
Old 19th July 2010, 08:42 PM   #149
Pafi is offline Pafi  Hungary
To make it clear: are these the specifications of the original UcD made by Bruno Putzeys?
Old 19th July 2010, 09:13 PM   #150
Tekko is offline Tekko
Banned
If it is, it have nothing what so ever to do with this design depicted in this thread, which aint a ucd what so ever. Its just another class d design by a diyer on a forum.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
