UCD 25 watts to 1200 watts using 2 mosfets
smps ossc card
Hi Exflaco
greetings this is pic of card please can you post crown lt schematic of lt amp for reference
warm regards
andrew:cool:
sir manoj
i have uf4004
is that ok ?
are you series about 15 OHM resistor near the bias ?
may be 1/5 OHM
i have 1k trimer too
IRFP250 can work in 400KHZ ?
hove can i find out amp ferequence ?
i need a frequence meter for this ?
i can work with protel altium
what is your program ?
please share your main file to me.
thanks
sir manoj
i have uf4004
is that ok ?
may be 1/5 OHM
thanks
Hi Hadi,
you can use UF4004 or any ultra fast diode with min 2A capacity.
not 15 Ohm it is 1.5 Ohm 0.5W resistor
i am not tested IRFP250 @ 400KHz.tested only 250KHz no problem found tested 300KHz working but over heated and sound not good may be gate resistor value is high(39 Ohm) anyway further i am not experimented.
for 1K resistor you will get @250KHz you need a DSO(digital storage oscilloscope)for finding frequency
MANOJ
