Go Back   Home > Forums > Amplifiers > Class D
Old 23rd October 2011, 03:10 AM   #1421
I just get the cores from kits and parts, t106-2, now i got a quiestion about the winding of the toroid. I need a 30uh inductance, but the mini ring core calculator app, says me i need 47 turns of AWG19, but i think the diameter of the wire its too small for +-35v? its about 70w rms.
So, i can winding 3 wires in parallel at same time on the core? even if i above the wires ?
Hope u can understand me and sry for my bad english.
Old 29th October 2011, 09:13 PM   #1422
CPX is offline CPX  Romania
AWG19 is enough up to 150 W rms in 8 ohm or 75W rms in 4 ohm
Old 15th November 2011, 12:30 PM   #1423
Can anyone help me please!?
Can anyone look at Farnell and write me here "order codes" for toroid cores that can I use for output inductor or whole inductor 20-22uH (15-20A current). I dont know what can I use because Farnell got lot of cores and inuctors...
I dont whant EE cores only.
Thank you!
Old 15th November 2011, 01:00 PM   #1424
theAnonymous1's Avatar
Does that mean you only want EE or not?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 15th November 2011, 01:02 PM   #1425
Without EE cores
Probably best solutions is "done" inductor or toroid core
Old 15th November 2011, 01:53 PM   #1426
lorylaci's Avatar
Send a message via MSN to lorylaci
Thank you!
For that you would need Micrometals or other iron powder toroids. Farnell does not have them. (at least i haven't found any so far)
Toroids, Ferrites, Parts, Kits, Toroid King, QRP Erector Set
Here you can buy them at a reasonable price, and they ship world-wide.
Olyan nem volt még, hogy ne lett volna valahogy
Old 15th November 2011, 04:47 PM   #1427
Yes I understand but I only can bay and order at Farnell from Serbia.. That why must to be Farnell
Any inductor for this amp up to 800W 4 ohms without EE ferrite cores
Old 15th November 2011, 06:41 PM   #1428
Pafi is offline Pafi  Hungary
You can use ferrite toroid, if you crack it into quarters, and place gaps into them. Size matters. (A > 150 mm^2, Vgap > 600 mm^3)
Old 15th November 2011, 07:13 PM   #1429
Dzony988, how many do you need?
I have some Micrometals T106-2 toroids. I have two already wound to 20uH and the others are 10uH.
I'm not sure that you can get 800W on these though.
Old 15th November 2011, 07:47 PM   #1430
I need 10+ peaces... I can't belive that Farnell doesn't have inductors or iron powder cores for it ))
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Page generated in 0.41680 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
