ucd 25 watts to 1200 watts using 2 mosfets - Page 141 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd October 2011, 09:21 AM   #1401
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by CPX View Post
There is a link in my post...
With optocoupler you will have no distorsions up to trip point since no active elements are present in the signal path...
can you send me too if its not ESP
Old 2nd October 2011, 09:22 AM   #1402
NMOS's Avatar
Originally Posted by Dzony988 View Post
Thank you NMOS
I tryed in simulator, but it has lot of distorsion and mestakes...
which simulator do you have ?
Old 2nd October 2011, 02:13 PM   #1403
CPX is offline CPX  Romania
In my link there is ESP schemattic.
Old 4th October 2011, 09:07 PM   #1404
This schematic were tested on LiveWire..
Old 4th October 2011, 09:28 PM   #1405
Ok.
Old 8th October 2011, 11:40 AM   #1406
stewin is offline stewin  Kenya
Originally Posted by fibko View Post
This is my schematic with overload protection. Sound on stabilized power supply +-30V is very clear without any parasite sounds. And when amp is on smps +/-80V sound is OK with little bit regulation frequency sound from SMPS and temp is also OK. Measured RMS power is 650W with 4 Ohm load. Mosfets are IRFP 250.
hi fibko i tried your schematic on a strip board and it worked without noise .you,ve managed to eliminate noise . i will try to in-cooperate the protection side later . the problem i was having was that one channel keeps going on silent after a while .but when i turn it off and on again it works . the other side has no issues . i think there is a problem with the lm311 or the c15 100u/16V near the input maybe . i used +/- 56vlts 700va toroidal transformer capacitors were 3300uf x 5pcs per rail rectifier diode was rbv5006
Old 8th October 2011, 11:47 AM   #1407
What about distorsions?
Old 8th October 2011, 12:23 PM   #1408
o.k guys i don't know how to measure and do calculations or to use an oscilloscope much of my amp and smps making i learned from you guys at diyaudio. but i do know how to read a digital multimeter and to assemble the parts i thank GOD. sorry for inconvenience caused.
but according to my ears there was no hf noise as was present using the original schematic. thanks
Old 8th October 2011, 02:54 PM   #1409
Pdf files are not working..
Use your ears with 1khz tone and put one 1 kohm 1w resistor between speaker and amplifier output.Next connect and disconnect 2 ohm load directly at output before resistor and watch for changes in tone .
Old 10th October 2011, 06:36 AM   #1410
redmx is offline redmx  United States
hi CPX ,
What is your link ˇˇˇˇ or can you send me too if its not ESP
best regards
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
