ucd 25 watts to 1200 watts using 2 mosfets
Old 8th July 2011, 09:38 PM   #1211
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by theAnonymous1 View Post
I've been contemplating this build since it was posted, but I have one question (which might show my ignorance of this circuits operation). Is there a reason why the LM311 is powered by only +/-3V? Anything wrong with using a higher voltage?
The comparator has a finit slew rate. So higher votlage would need more time to change output stage.
Also the driven 2N5401 cannot take much higher voltage at its base.
Olyan nem volt még, hogy ne lett volna valahogy
Old 8th July 2011, 09:43 PM   #1212
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I designed a similar amp with an LM393 comparator running off +/- 12 volts and it was fine. It was running at 250KHz ok.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 8th July 2011, 10:35 PM   #1213
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Thank you lorylaci.
Old 9th July 2011, 11:38 AM   #1214
NMOS is offline NMOS  Germany
NMOS's Avatar
can you share schematic
Old 9th July 2011, 08:16 PM   #1215
Use the same components as the other design and just run the comparator off +/-12v
Old 9th July 2011, 11:49 PM   #1216
NMOS's Avatar
whats the benefit compare to LM311
Old 9th July 2011, 11:54 PM   #1217
Probably no difference but I was just commenting that I found I could run my comparator off higher than +/- 3 volts.
Old 10th July 2011, 12:22 PM   #1218
fibko is offline fibko  Slovakia
I have one problem, my amp sometime starts beeping. I don´t know why. Can someone help me?
Old 10th July 2011, 01:11 PM   #1219
lorylaci's Avatar
Where does the beep come from? from the speakor, or from the amp's component (like output inductor)?
Do you have two amp modules operating?
If you have two amps opereting there can be interference (mainly beacuese the two close carriers). Try plugging off the other amp module. If beep disappears then you should try to minimise interference. (filtering supply lines, ground connection redirection)
What is the swithcing freq of your supply and your amp modules?
Old 10th July 2011, 01:24 PM   #1220
Beep come from speaker. Yes I have two amps and when one plugging off then beep disappears. SMPS run at 75kHz and amp at 250Khz.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
