ucd 25 watts to 1200 watts using 2 mosfets - Page 12 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th June 2010, 03:05 PM   #111
opor is offline opor  Thailand
This is mine .
Old 10th June 2010, 04:33 PM   #112
andrewlebon's Avatar
hi opor
greetings nice amp have u made new pcb design how is the amp working
and how powerful is it have u increased supply voltage
thanking you
andrew lebon
Old 10th June 2010, 05:25 PM   #113
Yes, I have made my own pcb. It works well. Amazing . I have not try to increase power rail yet. I will do it soon. But I have the same problem like many guy,coil is hot.Even through I try to use good coil from broken Behringer amp. Waiting for some suggestion.
Old 10th June 2010, 07:21 PM   #114
Send a message via Yahoo to ionutzxpo
Default class d
hi opor! can u share your PCB whit us/
Old 11th June 2010, 10:28 AM   #115
Sure.
Old 11th June 2010, 02:59 PM   #116
opor use T106-2 from micrometals (iron powder core)
Old 11th June 2010, 04:38 PM   #117
Originally Posted by opor View Post
Sure.
Hi opor,
Is it double layer pcb?
vijay
Old 11th June 2010, 05:26 PM   #118
Hello opor,
Appreciate if you could print the PCB layers into PDF or graphic file format.
Many thanks.
Old 12th June 2010, 06:16 AM   #119
rezamir is offline rezamir  Iran
hi opor
Do you have output scope diagrams and so on to share ?
best regards,
Old 12th June 2010, 03:49 PM   #120
It is PTH pcb.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
