ucd 25 watts to 1200 watts using 2 mosfets - Page 114 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th May 2011, 09:15 PM   #1131
fibko is offline fibko  Slovakia
Originally Posted by electroconico View Post
I used a 100pF cap instead 330pF.
Mosfet irfp250N with bypass dione mur120.
Power supply +-60vdc
Input signal less than 0.6vpp
Is it a saturation problem ??
I can't go up more than that.
When I removed 1u capacitors, I have the same problem. I thing this capacitors are very interesting for stability and I add 1000u and 100n
Old 18th May 2011, 09:20 PM   #1132
Originally Posted by luka View Post
does the coil get hot?
why do you use such small signal?
The inductor itŽs cold.
That is the signal level that it can use before to get the saturation.
I have the 1uF capacitors. IŽll add the 1000uF caps to watch if something could change.
Later IŽll try other inductor .
ty
Old 18th May 2011, 10:44 PM   #1133
Well, I changed the toroid core .
Now i can get more power , a little more.
Toroid core 22uH . It is getting hot quickly.
The output looks very clean . Now the oscillation goes up to 230KHz.
I got the saturation at more high level than before.
So I think the problem is the toroid core.
What do you think ?
Pics below :
Old inductor.
New inductor before sat.
New inductor Sat.
Oscillation and output.
Oscillation
File Type: png New_22uh_core_output_before_saturation.png (7.7 KB, 1219 views)
File Type: png Oscillating at 250KHz core solution.png (10.3 KB, 1163 views)
Old 18th May 2011, 10:49 PM   #1134
Did anyone test amp with T130-2 or T106-2 with 20-22uH?
Old 19th May 2011, 04:48 PM   #1135
Pafi is offline Pafi  Hungary
And something else.
But you didn't tell enough/any informations about neither the old nor the new core. Also the load is unknown.
I don't see any sign of saturation.
Old 19th May 2011, 04:59 PM   #1136
opor is offline opor  Thailand
I have an experience with T157-2, it works very well. At the same power rail ,others is get hot quickly.
Old 19th May 2011, 05:49 PM   #1137
Originally Posted by Pafi View Post
And something else.
5 ohms load.
inductor
How does it should look ?
The mosfets still cold.
At my firts try I built 200W@4 ohms amp
Power supply = 40Vdc
It did not go to distorsion also the volume wasnŽt set to full, but the output signal started to look like the pics showed , and a sound came out like sss ssss sssSS ss.
We got almost 130W
Old 19th May 2011, 06:02 PM   #1138
@ Laci
How can I increase swich freq above 400KHz with your schematic.
Do I need to change value of C17, output filter and gate resistors or what?!
Thank you
Old 19th May 2011, 06:29 PM   #1139
Hi guys, i want try this amp, i saw the original file of this amp and the post before this saying there is a much better ways to do the pcb and some improves on the circuit.
I anyone can tellme which board i should use and modifications on the circut, i dont want protections just the amp but whit the improves that u guys just make.
Ty and sry for my english, im working on it xD
Old 19th May 2011, 09:01 PM   #1140
And something else.
You are right , I have changed the core coil to air core and i had the same result almost at the same rate VRMS 29vrms.
So , the problem is in other place , IŽll check comparator output,Hin -Lin inputs and mosfet gate signals.
Any suggestion??
ty!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
