ucd 25 watts to 1200 watts using 2 mosfets
Old 5th May 2011, 01:00 PM   #1091
Dzony988 is offline Dzony988  Serbia
So,for electronic end led its need 12V. J1 is short curcuit and J2 conect to SD pin. SD pin goes directly to J2 or have something with Ucc-. Did you test this. If you didint, i want to test this on my amp.
What about with voltage to gate of BF and conections to Udd and Ucc- ?
Old 5th May 2011, 03:02 PM   #1092
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
The 12V supply is all referenced to the auxiliary supply of the IR2110. So the ground in this schematic goes to negative supply, SD pin is the SD pin of IR2110.
I haven't tested this, I've only simulated it.
Olyan nem volt még, hogy ne lett volna valahogy
Old 5th May 2011, 03:20 PM   #1093
Ok, then for power suplay we can use 12V from TIP41C, and where goes gate of BF245, to posotiv or negativ rail and how?
Old 5th May 2011, 04:00 PM   #1094
opor is offline opor  Thailand
Originally Posted by lorylaci View Post
Could you post pictures of your setup? (and about the layout too)
Here you are. Please comment.
Old 5th May 2011, 05:36 PM   #1095
lorylaci's Avatar
Why do you think everyone uses the same layout editor as you?
If you want help post things as, so we can help.
Please post pictures about your setup. (the module you built, with supplies... connected) I find my ask trivial, cause the problem is sure be there, then we can tell what.
Old 5th May 2011, 06:01 PM   #1096
This is my module. With +-42VDC .All on the heat sink is warm. Coil is cool.
Old 6th May 2011, 10:44 AM   #1097
This is my PCB.
Old 6th May 2011, 02:23 PM   #1098
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Hi Opor,can you convert the PCB file to PDF? for toner transfer please
or tell me the program to open the pcb
Thank You
Old 6th May 2011, 03:44 PM   #1099
Thank You
Protel99SE program can open this PCB.
Old 7th May 2011, 06:55 PM   #1100
stewin is offline stewin  Kenya
hi opor where do you buy or get the pads which you've put in your circuit . or was your board factory made.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
