ucd 25 watts to 1200 watts using 2 mosfets
Old 4th May 2011, 02:27 PM   #1081
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
You can always use a DC servo, maybe with some cap to a rail to kick the amp into oscillation on startup.
Old 4th May 2011, 04:44 PM   #1082
Dzony988 is offline Dzony988  Serbia
In feedbeck my resistor are 10K not 1K because I like more gain, but I followed Laci's sugestion about cap in series with R7 and everything is ok. I dont have DC offset and noise but I was use 100uF
Old 4th May 2011, 06:32 PM   #1083
opor is offline opor  Thailand
I have followed your suggestion. DC offset is OK. Noise is less without any connection at input. But when I just connected CD in but did not play any song, these is noise.Why?
Old 4th May 2011, 06:57 PM   #1084
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Do you use a shielded cable? Unshielded cable will pick up noise.
Look for earth loops too, because it will pick up every radioation from the board or output coil. Connect common to safety earth pole on the AC plug.
Olyan nem volt még, hogy ne lett volna valahogy
Old 4th May 2011, 08:19 PM   #1085
Maybe is a cable, try to short input and gnd without cable direct on pcb, you must not have any noise if everuthing is ok. If ypu have, look up at conections on input and output fets. I didnt try with 1nF on input, I try with 4.7n and 100p in paralel just like in previous desing
Old 5th May 2011, 04:56 AM   #1086
Default Overload protection without shunt res.
Hi to all
One good engineer from my country was recommended to me cheap and very good solution for overload protection without SHUNT resistor. He used this schmatic many times (for 30 years) and this is good because can use with any amplifier including this.
Actually its electronic fuse, very fast and stable and good because it has trim pot for setting current when amplifier will shut down.
Look at the schematic and read the word document that I atached. I belive you can understand because I use google translate from serbian to english.
What are you think?
Old 5th May 2011, 12:09 PM   #1087
I short input to ground noise is less but still noticeable. And I use shielded input cable.So cable is not a problem.
Old 5th May 2011, 12:09 PM   #1088
lorylaci's Avatar
Hi to all
What are you think?
"without shunt resistor" ???
There is a 0,3 Ohm + transistor shunt in your schematic.
It will dissipate more than a simple 0,033 Ohm shunt (for 20A current sense).
So this idea is idiotic. You can do better with only a shunt and 2 transistors per side.
Old 5th May 2011, 12:15 PM   #1089
lorylaci's Avatar
Could you post pictures of your setup? (and about the layout too)
Old 5th May 2011, 12:27 PM   #1090
lorylaci's Avatar
Here is my idea to decrease shunt dissipation. Current treshold can be set by the trimpot. By using a JFET the voltage need at shunt resistor is decreased (from 0,6-0,7V, to <0,2V), so as dissipation.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
