ucd 25 watts to 1200 watts using 2 mosfets
Old 27th April 2011, 08:24 PM   #1021
ghabrius is offline ghabrius  United States
ghabrius's Avatar
Send a message via MSN to ghabrius Send a message via Yahoo to ghabrius
Almost done, still haven't figured out that AC connection, probably goes straight to the secondary of mains transformer...
The new pcb will have the dzony's protection part..
Dimentions are 96mm * 45mm
Old 27th April 2011, 09:44 PM   #1022
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
The layout is not the best. One of the supply lines makes a loop around the comparator part. The other still goes straight next to them. Imagine the current path from power supply to speaker. Then imageine your right hand there, and check the induced magnetic field. It points right through the comparator part.
So this way there will be high noise, in the most sensitive part.
Lay the power lines so, that these high currents should flow next to less sensitive parts. The loop should newer contain noise sensitive parts.
Olyan nem volt még, hogy ne lett volna valahogy
Old 27th April 2011, 09:48 PM   #1023
Dzony988 is offline Dzony988  Serbia
Yes, AC conector goes to secondary of main transformer!
Relay will not turn on if you don have AC. On AC conector use 1N4007 and dont use 470nF, its bad, use 1uF 100V elko but be careful on polarity because on AC conector goes AC voltage from transformer and after 1N4007 its NEGATIV volatage, so negative pin of 1uF elko goes to R6 and positive pin goes to GND.
R6 has 0,5mA curent
so for example +-50V (50V / 0.5mA = 100Kohm)
Relay will not turn on if you dont have KTY81-122 sensor, but its D class amp, temp sens is not need if you have good heatsink and output coil.
If you conect short 1 and 2 conectors without sensor relay will turn on, if you don, relay will not turn on and protection led is turn on. That I want to use for overload protection with sunt resistor and mini relay (everuthing is ok, mini relay is turn on and have short conect to 1 and 2 pins, Amp is overload -shunt resistors turn of mini relay, 1 and 2 dont have conection and main relay is turn off, but temp led now have name overload )
If you have problem with cliping indicator (on example its show clip on 30VAC and true clip is on 38VAC), add before 1K resistor from amp before diodes 1N4004 10K trimer and calibrate him to show true clip (use osciloscope and constant signal, when sine is in clip, calibrate the trimer to turn on cliping led) but use R2 value from table that I post
Good luck
Old 27th April 2011, 10:12 PM   #1024
I forgot, on relay coil pins you can use led - named Active (show when relay is turn on), but from R5 to raley track use 2.2Kohm resistor and after him conect + of led, - of led conect to colector of BC639.
I atached new schematic in protection.zip with all changes that i told you!
Old 27th April 2011, 10:39 PM   #1025
ghabrius's Avatar
dzony, can I use 1N4148 instead of 1N4004? what is the current flowing there? I'll still use the temperature protection because who knows what can happen, even if the MOSFET losses are minimal..
Old 27th April 2011, 10:46 PM   #1026
ghabrius's Avatar
Here is a modification on supply paths.. I also switched to bigger relay from mfg Omron
Old 27th April 2011, 10:47 PM   #1027
I think you can but I didnt try. 1N4007 is substitute for 1N4004 and 1N4002 (that i use and work perfectly)
I forgot 1N4007 paralel with relay, anode goes to colector of BC639 and katode goes to R5. Thats be all
Old 27th April 2011, 10:48 PM   #1028
ghabrius's Avatar
OK I remembered that too
Old 27th April 2011, 10:58 PM   #1029
I used 24V 2x16A relay (coil is 1Kohm).That is important to calculate R5
Relay:
24V 1Kohm coil (24V / 1Kohm = 24mA)
(Supplay Voltage - 24V) / 24mA = R5 in Kohms
on example:
(60V-24v)/ 24V= 1.5K
36Vdrop * 24mA = 864mW resistor, but I use 5W always
I dont know can you use smd resistors because R1..R8 must be 2W, for +-90v must be 5W, exept R3, btw you have all power dispiations of resistor in table
If you use relay with other resistion coil, measure resistion first and calculate values for R5
Old 27th April 2011, 11:08 PM   #1030
ghabrius's Avatar
I will use a 48V relay. Coil is 4kOhm so the current is 11.5mA.
So I will need a 820R resistor which will dissipate around 0.1W so 1206 SMD resistor should be enough. By the way I won't put an active LED because the voltage will be around 50V and current limiting resistor will dissipate too much power..
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
