ucd 25 watts to 1200 watts using 2 mosfets
Old 24th April 2011, 05:00 PM   #991
Rafael S. M. is offline Rafael S. M.  Brazil
Anyone ever used this amp for full range systems?
It's what I'm thinking of riding in small boxes active woofer with 12" and titanium driver
behaves in the order of 1KHz.. 5Khz..10Khz ..? good or bad?
in the case would mount a 400W into 8 ohms
Old 24th April 2011, 05:33 PM   #992
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
ucd 25 watts to 1200 watts using 2 mosfets Send a message via MSN to authlxl
Default 2000W/4ohm rms power UCD class D SMPS inteagrated
Originally Posted by NMOS View Post
please check this russian UCD Bridge AMP
there is after LM311 a Quadruple 2-Input Positive-NAND Gates SN74AC00D IC for Phase invert....and rest of schematic looks like ours
is this a better solution for bridging with less devices and lower component count ?
have not so much experience
It is good circuit indeed ,we have developed some amp like this circuit,the concept same circuit not ,works well,powerful and stable,it is not perfect choose to select IRS2110 as driver,it is so hard to proper control the DT time.
2000W-4000W/40hm range behave uncommon.
Prototype pics below:
Old 24th April 2011, 05:39 PM   #993
We found output inductor a bit heat when continuous 1Khz sine wave signal added.output mosfet heat also,we have to revised it once again.test and burn-in good now,last pics below:
Old 24th April 2011, 05:42 PM   #994
Mostech is offline Mostech
Banned
Any datasheets?
Prices?
Dimentions
Old 24th April 2011, 06:17 PM   #995
electroconico is offline electroconico  Mexico
Nice amp
How did you solve the heat? or What was the problem??
regards!
Old 25th April 2011, 01:58 AM   #996
it is simple,we use 2pcs T130 coil in our inductor, heat down.For mosfet increase the drive voltage about 18Vdc should good method
Old 25th April 2011, 05:30 AM   #997
NMOS is offline NMOS  Germany
NMOS's Avatar
which IC do you prefer for IR2110 replacement
Old 25th April 2011, 03:27 PM   #998
Two methodsne is IR series DT control Floating Driver(irs20124/irs2092/irs20955 etc.),the other is high speed optocupler + mosfet diver+mosfet body diode unavailable circuit +RC delay circuit.
It is only ourselves experiences,maybe friends have good methods on it.
Old 25th April 2011, 05:24 PM   #999
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by electroconico View Post
Gate signal is closest to mosfet.
Power supply line is direct on mosfet pins.
Capacitors are closest to Drain and Source pins.
What do you think about this new pcb routing?
Is there anything to change ?
Ill apreciate your comments and tips.
ty
regards!
P.D. Ill add some test points to pcb.
PCB seems nice. C9 is not necessary, instead increase C6 to 1u ceramic. Then you can make gate drive path shorter.
What does the opocoupler do? Only MUTE function?
Use the normal connection of the comparator. I reccomend to redesign the input to be balanced. Then the 47k trimmer is not necessary, (if you decresease R5 to 10k then the offset is also smaller, or put a series capacitor with R2 to ground)
Olyan nem volt mg, hogy ne lett volna valahogy
Old 25th April 2011, 05:27 PM   #1000
lorylaci's Avatar
This weekend I made an amp with this (with modifications) for sound reinforcement in a church. It is very nice. The 250W @ 4 Ohm amp, with SMPS, and preamplifier with into a 20x10x6 cm box.
I reccomend you do biamping. It is much safer for the tweeter, and you can even push it much harder.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
