Go Back   Home > Forums > Amplifiers > Class D
Old 2nd May 2010, 10:29 PM   #1
jdubs is offline jdubs  United States
Default B&O ICE Module Problem - ASP1000
Guys,
I am employing these modules in my active speaker setup for the woofers. I hooked them up as follows:
-A/C power goes to the Neutral, Line, and Earth pins.
-Speaker driver output comes from the Vo+ (red) and Vo- (black) pins.
-Input is via the 3 pins labeled Vi+, Vi-, and AGND. I am running an unbalanced signal so, Vi- and AGND are tied together. To be perfectly clear, I am running and RCA -> 1/4" mono cable to a stereo female 1/4" connector which is then tied via Canare L-4E6S wire to the 3 inputs. The tip goes to Vi+, the ring goes to Vi-, and ground goes to AGND. Its unbalanced, so the ring and ground are the same.
I am not getting any sound from the woofers with this setup. There is a green light on the amp that is on (its on with both amps). Not sure what this means. Any tips on how I can get this amp working?
Thanks,
Jim
Old 3rd May 2010, 06:03 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Are you sure you are using the right pins on the input connector?
/U.
Old 4th May 2010, 03:10 AM   #3
Yes, I double checked. Also, just removed the Vi- connection and no go, still. This light is on inside of both amps (I'm running two, one for each speaker). The light comes on as soon as power is applied. Is this some sort of fault light? There is zero indication of a fault light in the B&O schematic. Ughhh...Any ideas anyone? Would pics be helpful?
Jim
Old 4th May 2010, 06:38 AM   #4
StigErik's Avatar
There is a red fault light located near the green LED, if I remember correctly.
Anyway, when you power up the module you should hear a slight "pop" or "click" in the speaker if you put you ear close to the speaker. Check that first.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Icepower ASP1000 Stereo Amp in Hexateq Case john65b Swap Meet 4 26th April 2010 07:56 PM
Icepower ASP1000 Stereo Amp in Hexateq Case john65b Swap Meet 0 22nd April 2010 03:12 AM
Endangered Audio - Gristleizer Module & New Module Line! endangeredaudio Vendor's Bazaar 0 5th March 2010 03:03 PM
ICE module 1000 ASP wilbur-x Class D 3 13th December 2005 10:07 PM
Page generated in 0.07356 seconds (73.78% PHP - 26.22% MySQL) with 10 queries
