Go Back   Home > Forums > Amplifiers > Class D
Old 22nd April 2010, 10:14 PM   #1
brookbh is offline brookbh  United States
Question first class d build suggestions.
What would be a relatively easy and effective first build for a class d amp for use with a pro audio coaxial, or pro style mid + waveguide and compression driver?
Also, what are thoughts on purchasing and upgrading the dayton dta-100? caps or bigger power supply?
any advice is greatly appreciated guys, thanks
brookbh
Old 23rd April 2010, 09:52 AM   #2
fb is offline fb  Australia
Are you looking to bi-amp/multi-amp, or passive crossover?
How much power do you need?
I'd look at either Connexelectronic or Class D Audio Home page.
If you only need a few watts, I'd recommend looking at the miniDSP/miniDIGI/miniAMP combo at MiniDSP
This combination allows for a fully digital signal path from SPDIF -> amp power stage. Power from the miniAMP is (continuous) either 4x10W@4ohm or 2x20@8ohm.
Old 25th April 2010, 11:49 PM   #3
I would like about 50 watts at 8ohm per channel.
Would one of the 4 channel class d audio amps be suitable for a first build? The only thing that concerns me is that with these kits you are looking at about $400ish for an amp. I would hate to screw up and be out $400.
What your thoughts?
Old 26th April 2010, 01:04 AM   #4
sendler is offline sendler  United States
Default Sure 2X100
These are cheap and offer good sound. Make sure to get the amp with the fan. The four channel boards have been unreliable. Use the MeanWell S-350-36 SMPS turned down to 32v which another great deal.
Sure Electronics New Tripath Board tc2000+tp2050
41Hz has nice kits and connexelectronics has a nice 3020 module if you want to spend a little more.
Scott
Old 26th April 2010, 02:30 AM   #5
So the sure board tp2050 is about $50, and the mean well s-350-36 smps is about $60?
I found the s-350-24 and the s-350-48 on Computronics Utilities for Unix and PRIMOS . Who sells the s-350-37 smps?
A smps would simplify the build a bit, and keeping the costs down would be nice. Are there directions for assembling the sure tp2050, I know there is a very broad guide for the class d audio boards.
Old 26th April 2010, 02:44 AM   #6
Default Assembled
Sure sell the amp modules and the SMPS. No assembly required.
Scott
Old 26th April 2010, 03:04 AM   #7
Thanks, i found the meanwell smps on sure's website. $31 is very reasonable.
Sorry i didn't assembling the board, but is there a diagram for the wiring and connections?
Old 26th April 2010, 06:48 AM   #8
gooki is offline gooki  New Zealand
Yes there's a connector diagram.
Want to build Large 3 Way - Suggestions for Drivers anilva Multi-Way 25 4th February 2010 09:43 AM
Suggestions for a Mini-Monitor Build jeffmoore17 Multi-Way 4 30th December 2008 04:07 PM
Need some suggestions on what to build. morphon Full Range 14 17th November 2008 04:05 PM
I'd like to build a 3-way. I could use a few suggestions. Thanks. mpmarino Multi-Way 6 26th February 2007 04:33 PM
want to build a DIY ribbon, need suggestions thadman Planars & Exotics 16 10th June 2006 06:39 PM
Page generated in 0.09009 seconds (77.36% PHP - 22.64% MySQL) with 10 queries
