Go Back   Home > Forums > Amplifiers > Class D
Old 21st April 2010, 03:41 AM   #1
fr1s is offline fr1s  Canada
Send a message via Skype™ to fr1s
Question 2*100 watt @ 4ohm TK2050 or LM3886 Gain Clone??
I'm looking to build an amp for my self, something That I can listen to my Trance/House and the rest of the music without any problem.
So I'm here stuck with two choices:
2*100 watt @ 4ohm TK2050 Class-D Audio Amplifier from Sure..
2*100 watt @ 4ohm TK2050 Class-D Audio Amplifier Board_Sure Electronics' Webstore
and
LM3886 High End Power
LM3886 High End Power Amp Refer Gaincard New - eBay (item 120479781649 end time May-10-10 01:00:56 PDT)
and I'm not really Sure which one to go for!
which one of them sounds better? and is better over all,
Money wise I know it's cheaper for me to build amp with TK2050 Board but I dont wanna go cheap on my sound so I wanna know which one I should get!
thx
fr1s
Old 3rd April 2011, 07:16 PM   #2
xslavic is offline xslavic  Moldova
Thumbs down IDEAs
hello ,i got from ebay 4 x LM3886 + Ne5532 Board but changed NE5532 to AD797 and want to biass it in class A (the opamp ) i didnt finished yet because i want to use only HIGHEST END components,and have some LME49xxx opamps in soic package to try,that should be better than yours ,it will have more power in class A,i think 20W,if you need instruction for biassing reply and ill post,it costed me around 150 euro a pair for stereo amp (200w *2 in class AB ) and i want another amp to build, a krell KSA 100 MKII clone , and i need help for it,i'm not an engineer but as the other human beings -good in mathematics,please ,i want a TEAM for high end acoustics with same directions --class A + Excellent DIY speakers
lets show the world what Internet means to us
Old 3rd April 2011, 07:17 PM   #3
i have the same power supply 4*22000 uF (same board )changed values of resistors,and leds to capacitors :|,hope it will wwork
Old 19th April 2012, 11:01 PM   #4
why stop with just one? Try a LM3886 at 27 volts built point to point on the IC chip itself. Then build a truepath from 41 Hz. It is based on a TA3020 tripath chip at 150 watts into 8 ohms. One of these will fill the void. If you are picky about your components, you could get both done for 350 dollars or less. It depends on what items you might already have.
Minimum gain for Tripath TK2050? sendler Class D 4 22nd December 2011 03:14 PM
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
FS: LM3886 Gain Clone Chips (19) bolserst Swap Meet 5 26th October 2008 06:35 PM
LM3886 gain clone vs STK4048XI for 4 ohm load filgor Chip Amps 0 25th September 2004 12:05 PM
2 lm3886 for 120w in 4ohm load audioloud Chip Amps 10 29th June 2004 07:40 PM
Page generated in 0.07675 seconds (74.85% PHP - 25.15% MySQL) with 10 queries
