IRS2092 How to drive more then one pair of output transistors? - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st April 2010, 02:57 PM   #21
Originally Posted by andrewlebon View Post
hi realforce
greetings how can we know if pcb is designed properly for
d class after all most important criteria is ground plane how does your
prototype sound
thanking you
andrew lebon
No no, this is not my prototype. I found it on some Thai forum few weeks ago and I wanted to build it. It is commercial product so I think it is good design.
Old 21st April 2010, 03:30 PM   #22
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
I have to ask one question,when the power up to over 1000W ,reverse current will very large,so the output THD will very high,I think we have to change the output MOSFET connect method and make the mosfet body diode shut down ,so output signal will excellent when driver current enough.
IRS2092 not good choice in high power class D topic,I think we have to use discrete parts for better sound and stable products.
Old 21st April 2010, 06:06 PM   #23
darkfenriz's Avatar
Keep gate drive return paths (from sources to driver) separate, possibly through 1ohm resistors. This helps a lot when parralleling, I didn't belive that until I was told to and tried myself.
Old 21st April 2010, 06:38 PM   #24
jej is offline jej  France
Hi RealForce,
IRS2092 is made for half bridge only. If you want to drive 4 MOS you have to use either 2 IRS2092 with synchronisation in BTL mode or 1 IRS2093 (4 channels) used in full bridge mode.
IRS2092 is able to drive 1A only and the choice of MosFet is important! Don't use Mos with a Qg greater than 30nC with a switch frequency of 400KHz
Old 21st April 2010, 06:54 PM   #25
Yes I also think that IRS2092 is not good at all. Right now I am working on modified version with discrete components.
Old 26th April 2010, 08:57 PM   #26
savu is online now savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
Originally Posted by ionutzxpo View Post
hello here is the schematic
have you tried building it?
best regards,
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 27th April 2010, 05:11 AM   #27
Send a message via Yahoo to ionutzxpo
salut Savu, nu am incercat sa o construiesc,deocamdata ma chinuie talentu la o sursa in comutatie foarte simpla si nu ii dau de cap
Old 27th April 2010, 09:33 AM   #28
savu's Avatar
if you live near Alba Iulia or Cluj Napoca i can help you with that smps you were talking about and you would have time for that schematic.
I have some experience in smps but in class d almost 0
best regards,
Savu Silviu
1'st rule of chess:
Old 27th April 2010, 02:06 PM   #29
silviu iti las id meu (ionutzxpo) si vorbim acolo mai mult daca ai timp eu lucrez de la 9 la 19 chiar si 20 seara ....
Old 27th April 2010, 04:04 PM   #30
savu's Avatar
ok i will add you in my buddy list ...
one thing:
english please because this is an international forum and we don't want to start a habit amonghst other forum members...
best regards,
savu silviu
1'st rule of chess:
Best way to use a PAIR of 6SL7ís to drive a 300B? sgerus Tubes / Valves 5 11th December 2007 01:41 AM
drive output transistors with an IC Jared Solid State 11 23rd July 2007 06:56 PM
Pro-amp to drive pair of subs Al Garay Subwoofers 2 20th July 2004 04:27 AM
Copyright ©1999-2017 diyAudio
