IRS2092 How to drive more then one pair of output transistors?
Old 20th April 2010, 10:33 AM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Use SMD (SOT-23) local buffer transistors (emitter followers) for each output MOSFET.
Although, this layout may work, parasitics make switching much slower resulting in much worse efficiency (and higher distortion) than in a proper SMD layout with 2+ layer PCB.
Parasitics will also limit the maximum rail voltage for safe operation.
3000W are possible with just four IRFB4227 when layout parasitics are low enough.
I use to feel like the small child in The Emperor's New Clothes tale
Old 20th April 2010, 10:59 AM   #12
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Default Irs2092
hello here is the schematic
Old 20th April 2010, 11:03 AM   #13
RealForce is offline RealForce
O great man, thank you so much.
Old 20th April 2010, 12:46 PM   #14
luka is offline luka  Slovenia
luka's Avatar
for diy I don't see how you would need more then 1 pair of fets for output, even with one it is ahrd enough
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 20th April 2010, 05:35 PM   #15
Old 20th April 2010, 08:25 PM   #16
luka's Avatar
typo... hard
I FEEL SLOVENIA
Old 21st April 2010, 12:34 AM   #17
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi eva
greetings can this circuit be constructed as it is with 3 output pairs
what output power would we get
thanking you
andrew lebon
Old 21st April 2010, 10:12 AM   #18
Originally Posted by andrewlebon View Post
hi eva
thanking you
andrew lebon
In my opinion it should work really good. I am not sure if UCP700 works on the same principle or it is full bridge but the only thing I am afraid it is the PCB design. But it is not that bad.
Old 21st April 2010, 10:15 AM   #19
luka's Avatar
from UcD is really good, but this on, well I hope it will work
I FEEL SLOVENIA
Old 21st April 2010, 01:03 PM   #20
hi realforce
greetings how can we know if pcb is designed properly for
d class after all most important criteria is ground plane how does your
prototype sound
thanking you
andrew lebon
IRS2092 How to drive more then one pair of output transistors?Hide this!Advertise here!
Best way to use a PAIR of 6SL7ís to drive a 300B? sgerus Tubes / Valves 5 11th December 2007 12:41 AM
drive output transistors with an IC Jared Solid State 11 23rd July 2007 05:56 PM
Pro-amp to drive pair of subs Al Garay Subwoofers 2 20th July 2004 03:27 AM
