Go Back   Home > Forums > Amplifiers > Class D
Old 19th April 2010, 09:19 PM   #1
coit is offline coit  Australia
Default Sure TPA3123D2 2*25W Amp
These class D amps can be configured in SE or BTL mode.The 2*25W Sure amp is set up as stereo.I don't think these are like the T amps.
Can this Sure amp be bridged?Should I invert one of the inputs?
thanks
coit
Old 19th April 2010, 11:45 PM   #2
theAnonymous1's Avatar
You would need some external method of inverting the signal to one of the inputs. Keep in mind the minimum load Resistance is 8R for BTL.
For BTL operation you can bypass the output capacitors.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 20th April 2010, 03:33 AM   #3
Thanks for the answer.Speakers are paralleled 30ohm.
coit
25w amp completed pudge667 Solid State 2 9th May 2007 08:57 PM
almost done, 25w amp pudge667 Solid State 10 21st April 2007 11:51 AM
25w amp pudge667 Solid State 2 17th April 2007 12:32 PM
25w amp pudge667 Solid State 2 4th April 2007 02:08 PM
Page generated in 0.07742 seconds (69.95% PHP - 30.05% MySQL) with 10 queries
