Go Back   Home > Forums > Amplifiers > Class D
Old 15th April 2010, 12:55 AM   #1
spikee5 is offline spikee5  Spain
Default Arjen`s MKIII or HLLY 20W TAMP-20 for TannoyF4???
Hi! I´m from Spain, (sorry for my english... )
This is my first post and I`m completely lost about t-amps...
I have a pair of Tannoy Mercury F4 and I want to buy a cheap/good amplifier for them.
So, here my doubts:
- Are they recommended for this kind of speakers? (I`ll use them in a small room)
- If yes, which one is better? (since I`m not a expert, do you think is worth the risk soldering a Arjen`s MkIII over buying "ready to go" HLLY`s T-AMP20 ?
many thanks!!!
Old 15th April 2010, 02:17 AM   #2
Davet is offline Davet  United States
Default Go for the Preassembled
The MkIII requires a power supply, chassis, rca input jacks, and output speaker jacks. Arjen sells a reasonably priced completed unit that includes all the above.
Arjen also sells a kit less chassis and power supply Arjen MKIII Kit. Everything else is included.
He offers a Completely Assembled MKIII. A power supply may also be ordered for this unit from Arjen (see the ad).
The Completely Assembled MKII is also available. A power supply is also available for purchase for this unit.
Any of these T-Amps and the Hlly should satisfy the needs of your speakers.
Davet
Old 15th April 2010, 02:58 AM   #3
wwenze is offline wwenze  Singapore
The ad of "Completely Assembled MKIII" does not show the MKIII, it shows a Topping amp instead.
Arjen helps distibute the Topping brand, but AFAIK Topping is another Chinese brand on its own (which also makes DACs).
Old 15th April 2010, 03:35 AM   #4
Default My Mistake
You are right about the Topping it is not the MKIII. However, it is a complete 2024 based T-Amp. For one who isn't handy with a soldering iron the Topping is an inexpensive entry T-Amp.
The MKIII is more oriented to the tweaker.
I have purchased a number of T-amps from Arjen and I have always been satisfied with his offerings. Although I have not purchased a Topping.
Davet
Old 15th April 2010, 05:55 AM   #5
sled108 is offline sled108  United States
sled108's Avatar
You could just get one of these...Just check the Lepai Thread...It's a TA2020 with a Power Supply, pretty much Plug & Play...About as Cheap as they come, but you will have a Solid Starting Point to take it as far as you Want..
Lepai TRIPATH TA2020 Class T Amp Hi-Fi Audio Amplifier - eBay (item 270563188415 end time Apr-23-10 15:34:13 PDT)
Lepai T-Amp with TA2020
Old 19th April 2010, 10:43 PM   #6
thanks guys for your advice!!!!
I think I`ll take the "safe road" and buy a Plug & Play one...
So... Hlly`s TAMP-20 or Arjen´s Topping TP20 MK2 ??? )
thanks!!!!
Old 20th April 2010, 03:17 AM   #7
defect9 is offline defect9  Ireland
defect9's Avatar
I would still go with the complete MKIII kit (not the topping) if for no reason other than the bolstered circuitry on the PCB, and the $15/10GBP PSU (free shipping if ordered together). All the connections are clearly marked.
That, and the flexibility of making my own case to match the rest of my gear.
but... if you must go the safe road, I'd go with the Arjen Topping.
HLLY TAMP-20 with TA 2020 CHIP! Tripath07 Class D 63 9th September 2010 09:20 PM
Arjen MKIII Enclosure Recommendation mrdon Class D 2 13th April 2010 11:26 AM
The HLLY TAMP-20 : TA2020 tryout Neomatth Class D 23 4th August 2009 10:09 PM
Page generated in 0.09306 seconds (75.59% PHP - 24.41% MySQL) with 10 queries
