Go Back   Home > Forums > Amplifiers > Class D
Old 12th April 2010, 11:35 PM   #1
Default ti 5709 evm
I am trying to understand why ti did certain things in there evm design linked here
http://focus.ti.com/general/docs/lit...0&fileType=pdf
1) Like i don't understand why the common mode resistors are 4.7kohm, I use R9=R10=R11=R12 = 1/(√2 • 2πfCC1) this formula i got off this page Understanding output filters for Class-D amplifiers | Audio DesignLine
in which case it is much lower for this design more like 3-6ohms, depending on fc. Can someone explain the rational 4.7kohms? Thanks
Old 13th April 2010, 02:14 AM   #2
It's looks like some of the TI chips in this family have internal pull-down resistors for the bootstrap capacitors (see Figure 1 in the TAS5709 data sheet), and maybe some of the chips don't. So R9-R13 are pulldowns for chips that don't have them internally. I'm guessing...but they are the wrong size and value to be part of the output filter.
Old 13th April 2010, 04:23 AM   #3
yeah good call, you would think ti would mention something about that in the 5706 datasheet.
Old 13th April 2010, 08:05 AM   #4
theAnonymous1's Avatar
TPA3122D2 CLASS D AUDIO POWER - Audio Amplifiers Forum - Audio Amplifiers - TI E2E Community
The 4k7 ohm resistors are used to discharge the dc blocking cap when the amp is turned off, either by removing the power supply, or putting it in shutdown. This helps with pop performance, so the absolute value is not critical.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Troubleshooting TI Class D EVM amp? fizzsweden Class D 4 18th July 2011 09:29 PM
WTB: EVM 15L (in Australia) lowpoke Swap Meet 2 3rd August 2010 08:54 AM
TI tas5112 EVM - output filter mod? ChuckT Class D 0 5th January 2007 07:36 AM
Opinions on EVM 15b pro? Jer Multi-Way 3 13th November 2003 02:20 PM
Tripath EVM experience MurrayP Solid State 12 3rd March 2002 06:42 AM
Page generated in 0.09125 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
