Go Back   Home > Forums > Amplifiers > Class D
Old 7th April 2010, 09:01 PM   #1
Default Need help to setup MOSFET driver
Hi everyone!
I have made the PWM modulator for my recent project which is building a class-D amp.
Now I need to drive some power MOSFET's with a driver. I have chosen ZXGD3003E6 because it has low rise/fall time (19ns) and it comes in the small SOT23-6 package.
I have looked in the datasheet and I need help from you guys to setup this driver, since I don't understand the datasheet. There are some resistor you need to add but I don't understand how you can calculate what value you need.
Also I need to split the PWM signal so the P- and N-channel get the correct signal, am I right?
I know you need to use a fast switching diode and a resistor added between. I have seen the value 100 ohm has been used in some schematics I looked at.
Could someone show how you do that correctly, and also help with the driver? I would be very grateful if you would help me
I have also posted some images of my PWM modulator. It includes schematic and signals from trianglewave and PWM output. Frequency is 403KHz (it says 390 in schematic, but thats wrong).
Datasheet: http://www.diodes.com/datasheets/ZXGD3003E6.pdf
Simon H.A.
Old 8th April 2010, 05:12 PM   #2
darkfenriz's Avatar
The driver you've chosen is a single mosfet driver, which is basically a complementary bipolar follower with separately adjusted switch-on and switch-off times. These times depend on many variables, like gate charge of the mosfet, miller charge, threshold voltage,... Typical values of gate resistors are 4.7-22 ohms, preferably lower value for switch-off.
You must choose some more things first, like N-channel only or complementary switching stage, half or full bridge.
I recommend some half bridge drivers from IRF and N-channel topology, simple and effective.
Old 9th April 2010, 08:42 AM   #3
Thanks for you reply. So actually that driver I used is useless?
But what driver would you recommend for halfbridge operation?
Simon H.A.
Old 9th April 2010, 09:09 AM   #4
81bas is offline 81bas  Germany
IR2110, IR2010, IR2011, etc
Old 9th April 2010, 09:10 AM   #5
Old 8th May 2010, 09:57 PM   #6
Okay, I have recieved some IR2110 chips, but I can't figure out how to connect the IR2110 to my PWM circuit or what it is called.
Any suggestion? I would like to make a BTL mode, but SE is also okay. I just need it to work, so I can do some testing and modding.
Thanks,
Simon H.A.
Old 8th May 2010, 10:15 PM   #7
nigelwright7557's Avatar
I would suggest having a look at irs2092.
This is a one chip solution to your problem.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 9th May 2010, 06:58 AM   #8
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Thanks,
Simon H.A.
The keyword here is levelsifter.
Look here for some more information 6000W By IRS2092 ......
You can skip the topmost transistor .. as you can read further on.
Also you wil probably need some deadtime implementation like the circuit around 74HC86 .....
Good luck
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 9th May 2010, 04:44 PM   #9
Thanks for the replies. So I can use this connection to my IR2110? And I can remove Q1 and connect PWM to R3?
Can I use 74LS86 instead of 74HC86 (easier for me to get)? They should be the same right?
Simon H.A.
Old 18th May 2010, 10:55 AM   #10
Ok, here is my new schematic. Will it work and can you make some improvements?
Simon H.A.
gate driver transformer setup zilog Power Supplies 10 11th April 2008 05:33 AM
Trying to match a sub driver with setup TheOtherSide Subwoofers 1 11th September 2007 02:27 PM
Dynaudio Driver Matching for Multichannel Setup jjfox Multi-Way 2 21st April 2006 04:29 AM
suggestions required on mosfet matching setup for aleph x pamaz Pass Labs 4 20th February 2004 12:17 PM
Page generated in 0.11439 seconds (79.50% PHP - 20.50% MySQL) with 11 queries
