Arjen Helder Buffer V2
Old 8th June 2011, 12:24 PM   #61
Bill poster is online now Bill poster  Thailand
Bill poster's Avatar
Just checked out this thread- great info. I'm thinking to use the hifimediy dac (1853) with the Helder tube buffer and a TK2050 T amp from either Helder or Hifimediy.
I take it the Helder tube buffer will work with the Hifimediy amp?
Old 26th July 2011, 03:02 AM   #62
whaleman is offline whaleman  United States
whaleman's Avatar
Yes, as far as I can tell, it works with any amp and it does a very good job with the right tube. Actually, it does wonders. Here it is playing with a HIFIMEDIY T4.
This is my second Helder tube buffer implementation that I use in a tape monitor fashion, it really adds a lot of richness, detail, and body to the sound. I am using a donor 12 VDC SMPS power supply from a router or modem. It is great for adding to an iPod or some other weak signal as an extra layer of amplification.
The case is from www. mouser.com, you drill all your holes, it is a blank box. Worth every dollar.
I hope version 3 of his buffer is as good or better. This has got to be one of his better products.
WHALEMAN
The Cathedral Speaker Co.
Old 28th July 2011, 10:52 AM   #63
darkfury is offline darkfury
Did you try Arjen buffer V2 with Hifimediy T1 amp? and are the results similar?
Old 28th July 2011, 12:06 PM   #64
wow. Love it! To be honest I'm worried about my electrical knowledge/skills, so I might wait until you want to sell me yours
Old 10th October 2012, 08:39 PM   #65
ief is offline ief  Netherlands
ief's Avatar
I know it's an old thread but relevant to me so here goes...
Would it be a problem to swap the ecc82 with a ecc81?
I know i will loose some gain but other then that?
Old 13th October 2012, 02:17 AM   #66
tubesteve is offline tubesteve  China
tubesteve's Avatar
Location: since 1998 in China as an electronic consulting design and testing engineer
Default tube swap
you can swap the tube (ECC82 / 12AU/) to ECC83 / 12AT7 without any problems. the sound will be a bit different, also the sensitivity.
Swap to ECC83 / 12AX7 will create more distortion.
R&D
The amount of humans is increasing, but the amount of available intelligence remains a constant.
Old 13th October 2012, 08:10 PM   #67
ief's Avatar
Tnx Steve, in that case my 1958 tubes will remain silent I suppose, to bad.
Old 13th May 2013, 06:33 PM   #68
Gost22 is offline Gost22  Bolivia
Banned
Thumbs up Complete schematics for tube buffer
Hi M-r Whaleman!
Do you insert you can the complete schematics for this tube buffer.
Thank you and cheers!
Old 14th May 2013, 12:42 AM   #69
whaleman's Avatar
Originally Posted by Gost22 View Post
Hi M-r Whaleman!
Sorry, but this tube buffer is long gone. You might find the tube buffer on eBay still.
Best of luck,
WHALEMAN
Old 14th May 2013, 03:23 AM   #70
Banned
Where is the schematics?
thank you!
Arjen Helder Buffer V2Hide this!Advertise here!
Helder MKII TA2020 Amp PSU Wiring Obe1 Class D 10 22nd January 2014 01:33 PM
Good Experience with Arjen Helder mfong Class D 6 10th May 2011 07:07 PM
Arjen's helder TA2020 MKiii went fault :( chchyong89 Class D 13 17th September 2010 10:24 PM
Arjen MKIII Enclosure Recommendation mrdon Class D 2 13th April 2010 11:26 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
