| Class D Switching Power Amplifiers and Power D/A conversion |
#11 | |
"Due to too much POP noise when starting the PREAMP, we have replaced the input capacitors to 2.2uf." First of all, I thought the 2.2uF caps on the V2 buffer board were the output caps, not the input caps. Should I put the 2.2uF caps back in place?
Rich |
#12 |
Hi Rich
The output caps are the large red ones, they can be removed if the buffer is feeding into a module that has input caps on it. You must have a cap somewhere either on the amp module or on the buffer. Basically with both output and input caps in series you roll off the bass more. I have no problems with big pops but there will always be a small pop, it was the input caps for the buffer they replaced with a smaller one, there is no need to replace that. |
#13 |
i have mine all set up now, on power up the speakers are kind of sucked in and slowly return to the middle and i get a very loud pop when i turn it off .... hummm
#14 |
I measured the DC voltage on my speaker outputs of my TA2020MkIII amp with the MkII tube buffer. On power up, I read -2.4V on both channels. It starts to decay to about +8mV in about 10-15 seconds. The first time I powered up, it sent the T-amp into fault mode. On second power up, I got the same surge, but the T-amp remained on. I can't make any adjustments on the DC bias pots to bring the DC as close as possible to 0mV. After the initial surge on the second power up, I plugged in some cheapie test speakers and I have decent sound out of both speakers. I am very concerned that I cannot use this product with my T-amp, which is a shame, because I really wanted to further improve the excellent sound quality I get from my T-amp.
Rich |
#15 |
I turned the amp off and I get the really loud pop too. Does anyone have any ideas on eleiminating/reducing this pop on turn on and turn off?
Rich |
#16 |
i hope so, ive emailed arjen and he doesnt even know
#17 |
I've got the same problem of the loud pop. I hope someone knows how to solve it.
#18 |
Arjen has emailed me to inform me that he's working on a solution. I'm not sure how the solution will be implemented (another PCB to buy). For now, I can't risk damaging my speakers with -2.4V DC on turn on. I haven't measured the turn off DC voltage, but the pop is louder.
Rich |
#19 | |
So let the amp always ON. Itīs also better for receiving immediately best performance without any warm-up ![]() ----------------------- But another newbee question from me regarding the way from the cinch sockets of my CD Player to the V2 buffer amp: how to handle with the black mass cable on the board which is shared from the right and left input together ? Cinch outputs have for each channel the separate mass contact and if I am not wrong itīs the outer ring which is mass, or ? Last edited by TheDealer; 18th May 2010 at 06:07 PM. |
#20 |
yes it will be another pcb that cuts the speakers off with a relay and to be honest i haven't got the room in my case for another pcb plus i dont really want another pcb in the signal path ....not too happy
| Helder MKII TA2020 Amp PSU Wiring | Obe1 | Class D | 9 | 7th June 2011 03:22 PM |
| Good Experience with Arjen Helder | mfong | Class D | 6 | 10th May 2011 07:07 PM |
| Arjen's helder TA2020 MKiii went fault :( | chchyong89 | Class D | 13 | 17th September 2010 10:24 PM |
| Arjen MKIII Enclosure Recommendation | mrdon | Class D | 2 | 13th April 2010 11:26 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
