| Class D Switching Power Amplifiers and Power D/A conversion |
ive got a arjen ta2020 mk3 board and a smps i get a very small pop/crackle on power on of the amp, how do i correct this problem ??
#2 |
Hi onis,
I've got the older MKII version. If I power the MKII on with nothing connected to the input wires I get virtually no pops or crackles. Likewise, if I do have a music source connected and that source is up and running before applying power to the MKII, I get virtually no pops or crackles. Conversely, If the MKII is powered on before the music source is plugged in or turned on, then I do get some unpleasant bursts of noise. Try playing around with the power up sequence of your MKIII and your music sources to see if that helps. |
#3 |
yep same here but what is causing it ?? and how do i cure it...? is it a ground loupe ?
#4 |
Hi onis,
Ground loop problems typically create a constant hiss or hum. What you described is just a momentary pop / click, so that's not it. I can't tell you all the things that can induce this pop / click issue, but I do know that capacitors in the source equipment defiantly can cause this problem. In my case, I just make sure to power on the amp after I have my source connected and turned on. Likewise, I power the amp off before disconnecting or turning off the source. Last edited by Obe1; 5th April 2010 at 05:19 PM. Reason: typo fix |
| hk 770 snap crackle pop | new_wes | Solid State | 1 | 23rd May 2010 07:13 AM |
| HOT ROD DELUXE: CRACKLE...POP...what to do? | juicy1484 | Tubes / Valves | 17 | 29th April 2010 02:08 PM |
| Preamp snap crackle pop | meaghers | Solid State | 15 | 25th May 2009 10:54 PM |
| Snap crackle pop, I KILLED MY AMP PLEASE HELP!!! | imperfectcircle | Solid State | 20 | 10th February 2007 06:32 PM |
| Pop/crackle in one channel | Saurav | Tubes / Valves | 16 | 28th November 2004 11:21 PM |
| Page generated in 0.08339 seconds (63.98% PHP - 36.02% MySQL) with 10 queries |
